FS: air/air intercooler, air/water intercooler setup, and shaved -12 vented B series valve cover w/
Old Aug 12, 2008 | 10:08 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default FS: air/air intercooler, air/water intercooler setup, and shaved -12 vented B series valve cover w/
i have these parts laying around taking up space. i will never use them so maybe you can.
*mid size air to air intercooler. core dimensions: 24"x3"x6 1/2". 2" in, 2 1/2" out (bead rolled ends). est HP support ~500 give or take. fits EG civic center opening perfect. unsure of manufacturer.
-$120 shipped
*1 minor ding/dent shown here in pic
*custom converted air/water core (11"x 3 1/2"x7") (2"in, 2 1/2" out), vortech reservoir and pump, setrab 20 row cooler (pt # 50-920-7612), and lines. est HP support ~500 give or take without modifications...set up heat soak barrier, chill, and mod inlet and outlet for more power support. perfect for sleepers.
-$375 shipped
*shaved and cam gear cut b-series valve cover with 2 front -12 ports, fittings and lines, moroso catch can with 4 ports and a drain and filter. true color=fluorescent red. strip and repaint over the ill racecar steeziness if you must. has brackets welded on back for coil packs.
SOLD
*misc other non FI fs stuff:
-skunk short shifter
$50 shipped
-prothane insert upper motor mount and bracket, DC alum/steel mount w/ hardware
$70 shipped
-brand new unopened OEM p2t/p30/b16 timing belt
$30 shipped
-'99 a4 h22 crank. excellent condition. comes with 19mm crank bolt
$100 plus s/h
-h23 non vtec usdm crank. great condition.
$100 plus s/h
-h series oil squirters w/ all hardware and bolt
$40 shipped
-mint jdm CTR front strut bar. crinkle red you know the deal. perfect OEM JDM mate for your pretty ITR/CTR valve cover.
$80 shipped
*that's it. these are fair to me asking prices...semi flexible. if you can get it cheaper on ebay etc etc, then by all means go ahead! not really looking for any trades but it won't hurt to offer trades, trades + cash.
Modified by not so civic at 5:23 PM 9/16/2008
Old Sep 14, 2008 | 02:10 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: FS: air/air intercooler, air/water intercooler setup, and shaved -12 vented B series valve cover
pm
Old Sep 15, 2008 | 03:27 PM
pm'd back...ttt make offers on this stuff. need to sell.
Old Sep 15, 2008 | 08:09 PM
mannyman's Avatar
good stuff here guys... buy buy. VC is pending
Old Sep 15, 2008 | 09:12 PM
95boostedh22's Avatar
hey let me know if the h23 crank is still up for grabs if so lmk asap i need it....email me at banginryder16@aim.com because i do not know how to PM you
Old Sep 16, 2008 | 08:08 AM
still up for grabbage. i will send you an email.
*valve cover/breather setup is SOLD*
Modified by not so civic at 5:24 PM 9/16/2008
Old Sep 17, 2008 | 09:07 AM
00si2's Avatar
PM Sent
Old Sep 22, 2008 | 08:38 AM
00b18c5's Avatar
I wanted that VC
NLR808
Aug 5, 2004 04:49 AM
blitz118
Jun 25, 2004 08:39 PM
