b18c1 swap question
hey i'm getting a 88 Si soon, and what all is involved in doing a b18c1 swap into it?
origionally i was going to do it into my 92 dx hatch, but i think it would be much more fun in a crx
thanks
thanks
It'll be real fun but a lot easier on an EG...and maybe cheaper. But its your call... check out http://www.hasport.com for more info....Just off the top of my head, you'll need the following: if running obd0
axles 91 teg
distributor 91 teg
injectors 91 teg
PR4 ECU
rear bracket 91 teg
Engine Mounts (Hasport or Place)
Shift linkage
Since you have an Si, I'm not sure if you can use your distributor and injectors...but for sure you can reuse your injector resistor box...
axles 91 teg
distributor 91 teg
injectors 91 teg
PR4 ECU
rear bracket 91 teg
Shift linkage
