b18 questions
I am going to a nearby import junkyard tomorrow and i need to know the differences between all these. i want to do the b18 swap. just the 1.8L DOHC non VTEC. whats the code for that? im confused with all the b18a/b/c and the numbers and stuff. if any one could help me out thanks.
cliff notes: engine code for 1.8L DOHC non VTEC
I does make 130 HP cause the intake manifold is longer on it. Just swap it for a shorter one and you should make 140 HP after! My friend has one in his car and we did the swap. Pretty straight forward!
Here's what I found for info:
2nd gen teg engine specs - 90-91
130 hp @ 6000 rpm
121 lbs.-ft. (16.8 kg-m) @ 5000 rpm
The other 2nd gen teg specs - 92-93
140 hp @ 6300 rpm 160hp @ 7600 rpm
126 lbs-ft (17.4 kg-m) @ 5000 rpm
Hope this clears things up for ya
130 hp @ 6000 rpm
