Daytime running lights question.. (08' Si)
I want to change the bulb on it. I havent looked yet to see how hard it would be to swap out but what do you guys rate it?? Also, what is the bulb size?? TIA.
An even better question, is if there is a way to turn those off but still function under high beam? That **** is wack when you're trying to chill at the local illegal street "cough cough" spot and people are asking you to turn em off and you can't....stupid DLR...
never knew they came out wiht HIDs on si's
pull the fuse out for it under the dash..
fuse #37
Modified by jeiarneesi at 9:53 PM 8/19/2008
fuse #37
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeiarneesi »</TD></TR><TR><TD CLASS="quote">never knew they came out wiht HIDs on si's
fuse #37</TD></TR></TABLE>
they didnt come with HID's
fuse #37 </TD></TR></TABLE>
#37 you say? Sweet!
#37 you say? Sweet!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal07Si »</TD></TR><TR><TD CLASS="quote">werd, I pulled that fuse a while back. So much better now.</TD></TR></TABLE>
how much horsepower did it add?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeusone »</TD></TR><TR><TD CLASS="quote">
how much horsepower did it add?</TD></TR></TABLE>
no hp added
but I did gain 56 wtq
no hp added
Sorry it took so long. The sticker is on the driver side door jamb on my 08' Si. its a bad cell phone picture but ill translate:
This vehicle may contain mercury containing devices installed by the manufacturer:
HIGH INTENSITY DISCHARGE HEADLAMPS
Navigation Display
Back-Lit Instruments
Overhead Mounted Video Display
Remove devices before vehicle disposal.
Upon Removal of Devices
Please Reuse, Recycle, or Dispose
as Hazardous Waste
Navigation Display
as Hazardous Waste
From: Westminster/Huntington Beach/Seal Beach, CA, United States
thats probably just a sticker they put on all hondas/acuras and saying as some hondas and all acuras have HID's, thats probably why its listed on the sticker. Cause does ur car have the navigation unit?, and I know it doesn't have the Overhead Mounted Video Display. So just cause it's listed on the sticker doesn't mean ur car has it.
Look at your first line,
This vehicle MAY include mercury containing devices installed by the manuf. - then lists all the possibilities, they probably use the same sticker on Acuras (that do have factory HID's) and S2000s (that do have factory HID's). You received that sticker because you have navigation, not because of HID's.
Other than those vehicles Honda does not make a car with factory HID's. Period.
