broken valve stem
Old Aug 11, 2008 | 07:28 PM
higgunscrx's Avatar
Default broken valve stem
ok so i was driving to work today and i got a flat. i threw the donut on and got to work only a few mins late. so i decided to check out where the leak was on my break and found out it was leaking from the side of the valve stem. so i went and bought a new one and went to install it and the old one broke when i pulled on it and the bottom half fell inside the tire. i couldn't get the piece out of the tire so decided to just leave it for now. installed the new valve stem and pumped up the tire. i would like to know if this is a bad idea to drive with this piece of the valvle stem inside the tire? should i go to a shop and get them to remove one side of the tire to remove the piece? anyone ever had this happen to them?
Old Aug 11, 2008 | 07:45 PM
vtecb18c's Avatar
Default Re: broken valve stem (higgunscrx)
you shouldnt have any problems with it but since it seems like you dont have the best of luck, i would go get it taken out before somethin else happens lol(those damn black clouds they suck)GL
Old Aug 12, 2008 | 07:06 AM
Crx Jimmy's Avatar
the stem has to be removed from inside the tire, and the new one should have been pulled through the back as well, not sure how you got it in there from the front. I would have them take the tire off and fix it
Old Aug 12, 2008 | 07:16 AM
Error.thatusernamehas...'s Avatar
Default Re: broken valve stem (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">the stem has to be removed from inside the tire, and the new one should have been pulled through the back as well, not sure how you got it in there from the front. I would have them take the tire off and fix it</TD></TR></TABLE>
Thats what I'm thinking.
Old Aug 12, 2008 | 01:05 PM
xci_ed6's Avatar
Default Re: broken valve stem (Error.thatusernamehas...)
you can break the bead with a 2x4 to install a valve stem, but with only the bead broken it is damn near impossible to get a hand in and try to ****** the lil black rubber thing. I wouldn't call it unlucky either, valve stems do break, that's why they should be replaced with the tires. It's also cheaper than replacing a tire.
No harm will come of it, might hear it bouncing around, but I doubt it.
Old Aug 12, 2008 | 01:50 PM
GroundZer0 336's Avatar
Default Re: broken valve stem (xci_ed6)
i work at a tire place and have seen people driving around with alot more than the bottom of a valve stem in their tire...pliers and such..so its not a big deal that its in there it wont hurt anything, might cause a small vibration but i doubt it. just go to a tire place and ask if theyll replace it. we never even charge when people have broken ones.
racerrck1
Aug 16, 2008 03:03 PM
zspy_007
Dec 14, 2007 06:25 PM
loudsubz
Nov 24, 2007 11:27 AM
hondasarefast
Dec 6, 2006 08:46 PM
311
Sep 8, 2004 09:07 AM
