S1 transmission....
where is the speed sensor located at on the s1 cable transmission i want to install an electronic speed sensor so i can hook up this gsr cluster and i have no idea where the speed sensor is locate
i feel like an idiot but can anyone help me out here
Modified by wesleywhite989 at 6:49 PM 8/11/2008
i feel like an idiot but can anyone help me out hereModified by wesleywhite989 at 6:49 PM 8/11/2008
should be on top of the tranny close to the fire wall. should have a cable coming out of it. The cable should lead toward the cluster area on the fire wall.
alright so its pretty much impossible to see in my lil engine bay..... i thought it was back there like behind/under the starter but wasnt sure thanks for clearing that up for me ill drop it this weekend to take a better look and get an idea of what vss i should use
I have never had any problems locating the speed sensor in any of my efs. the cable comes out from the middle of the fire wall and leads to the tranny directly under the intake. pretty easy to see and fairly easy to get to reach.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norbs_crxsi »</TD></TR><TR><TD CLASS="quote">the speed sensor on most cable tranies are inside the dif housing</TD></TR></TABLE>
uh what? on 88-91 d-series cable transmissions, the speedo cable goes into the speed sensor on top of the transmission, and the speed sensor can be removed via 2 bolts.
There IS a gear inside the transmission on the diff housing, but you don't need to change it to swap to an electronic vss.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp »</TD></TR><TR><TD CLASS="quote">
There IS a gear inside the transmission on the diff housing, but you don't need to change it to swap to an electronic vss. </TD></TR></TABLE>
If I read correctly, its not a D series, it is an S1 = B series....but yeah, its in the same spot. On the back of the trans, directly under the throttle body.
Not hard at all to find, follow the cable.
