difficulty level? b16a3 into 93 hb cx vis versa sohc vtec into Del sol
Old Jul 22, 2002 | 08:17 PM
khang77642's Avatar
Default difficulty level? b16a3 into 93 hb cx vis versa sohc vtec into Del sol
*did search already
what is needed to put a b16a3 motor in 92 civic hb cx and vis versa about putting a dy6z6 into del sol.
basically I am taking the b16a3 motor from a del sol and putting it in my car and at the moment I have a 94 sohc vtec dyzy6 that I want to put in the del sol. would everything fit with little modification? What is needed ? thanks in advance.
I know del sol come with the dy6y8 motor. So it might not be hard , but I want to know from anyone that had past experience.
[Modified by khang77642, 11:19 PM 7/22/2002]
Old Jul 23, 2002 | 04:36 AM
AmauryR's Avatar
Default Re: difficulty level? b16a3 into 93 hb cx vis versa sohc vtec into Del sol (khang77642)
actually we just finished putting a '95 b16a3 into my boy's civic cx. everything bolts up (you can reuse your upper mount, etc...). wiring-wise - you'd need to run the vtec, vtec oil press, and vtec ground wires (as well as knock sensor, etc...)
you'd need (from the del sol vtec) - p30 ecu, engine harness, axles, linkage, etc...
(below pic by Katman)
now to put the d16z6 into the del sol vtec shell - you need the old linkage, axles, wiring harness (engine) and p28 ecu... if u wanna use ur old cx ecu and engine harness (to get the car "just" running) get a msd switch to activate the vtec. but the car won't run like it would if it had the p28 and the d16z6 engine harness...
1997Accord
Jan 18, 2007 06:18 AM
Contender25
Dec 12, 2006 06:06 PM
honda etr (vw)
May 21, 2005 08:46 AM
EFMAN
Apr 5, 2005 11:52 AM
theguy003
Jun 7, 2002 05:15 AM
