OIL PSI LIGHT!! SPUN ROD BEARING!! HELP!!
Old Aug 11, 2008 | 03:39 PM
gloryman_17's Avatar
Default OIL PSI LIGHT!! SPUN ROD BEARING!! HELP!!
i have a 2005 honda civic, with the dezod turbo kit internals and all im also using kpro
i was driving down the interstate when all of a sudden the oil psi light started blinking and then it went solid i pulled over and turned the car off to check my oil and my turbo i let the car sit for about 25 mins then checked the oil and it was fine the turbo was also fine, i jacked the car up ( yes on the side of the effin interstate) and i had no leaks or holes, i then started the car to hear a awful knock which happend to be a spun rod bearing but the oil psi light it no longer on and doesnt come on i took the motor to 3500 rpms and it still did not come on, does this sound like a bad oil pump?
spoolin08
Jun 2, 2011 04:40 AM
gloryman_17
Aug 12, 2008 02:59 AM
S2KILLA
Apr 12, 2007 12:11 PM
b.d.racing
Aug 7, 2006 09:54 PM
