Is there something wrong with my diff ?
Old Aug 11, 2008 | 03:02 PM
EdSiXxXrR's Avatar
Default Is there something wrong with my diff ?
hey whats up, i have a 91 ed6 with a jspec 97 itr in it. for axels im using integra da ones and also the intermediate shaft as well. at first my problem was the passenger side axel kept popping out from the tranny, no matter how many times i replaced it the same thing happened. finally i replaced for the 3rd time and after i was done from getting the car of the jacks i tried pushing the car backwards a little to clean up the mess and the tranny just locked itself. the car wouldnt go forward or reverse. i tried pushing it again and finally it moved. i drove around the block and it felt like crap,as if the car wanted to lock again. so yea any help would be appreciated it. sorry for the long paragraph.
p.s. a couple days before replacing the axel the gears felt rough going in.
Old Aug 12, 2008 | 03:50 PM
EdSiXxXrR's Avatar
Default Re: Is there something wrong with my diff ? (EdSiXxXrR)
anybody have any ideas ? input ?...
Old Aug 12, 2008 | 05:12 PM
vtecb18c's Avatar
did you check the tranny fluid?
Old Aug 12, 2008 | 05:16 PM
JustAnotherRex's Avatar
Taking out the dust ring?
Are you matching axles to half shaft?
Old Aug 12, 2008 | 10:44 PM
EdSiXxXrR's Avatar
everything u guyz mentioned has been checked,done and taken care of.......
Old Aug 14, 2008 | 04:52 PM
autowrench07's Avatar
Default Re: (EdSiXxXrR)
hey i had this same exact problem in my old eclipse its guna sound retarded but my frame was torn right infront of the front suspention assembyly and it wasnt alowing my axle to line up creating huge problems check that out i know it sounds crazy tho
Old Aug 25, 2008 | 11:00 AM
EdSiXxXrR's Avatar
Default Re: (autowrench07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autowrench07 &raquo;</TD></TR><TR><TD CLASS="quote">hey i had this same exact problem in my old eclipse its guna sound retarded but my frame was torn right infront of the front suspention assembyly and it wasnt alowing my axle to line up creating huge problems check that out i know it sounds crazy tho </TD></TR></TABLE>
i had my frame checked prior to this bro. my frame was straight. i just pulled out the tranny and swapped it for another since its my daily driver. as soon as i have time ill take apart the other tranny and figure it out. thanx anyways tho...
GrantFuentes
Mar 25, 2014 04:10 AM
EdSiXxXrR
Transmission & Drivetrain
Sep 3, 2008 02:17 AM
frankenstienEk
Apr 10, 2006 08:28 PM
gsrHB
Sep 20, 2005 07:50 PM
ABK
Apr 6, 2004 08:30 AM
