how to fix code 9
Old Aug 11, 2008 | 02:44 PM
ef_zc's Avatar
Default how to fix code 9
first off i have dohc zc and i know my timing is good i just check again what else could through a code 9 thanks for any help
Old Aug 11, 2008 | 06:36 PM
ef_zc's Avatar
Default Re: how to fix code 9 (ef_zc)
anybody
Old Aug 11, 2008 | 06:55 PM
accordaffair's Avatar
either the timing is off or the distributor in the sensor has failed, meaning the whole distributor needs to be replaced
it reads the position of the crankshaft, so if that is off it will throw that code. Does the car run ok?
Old Aug 12, 2008 | 03:13 AM
ef_zc's Avatar
Default Re: (accordaffair)
it runs ok now it was a tooth out but i fixed it but it is still throwing code 9
Old Aug 12, 2008 | 03:30 AM
kirbyman's Avatar
Default Re: (ef_zc)
have you reset the codes since fixing the problem?
Old Aug 12, 2008 | 06:44 AM
ef_zc's Avatar
Default Re: (kirbyman)
i disconnected the battery for a 5 mins
Old Aug 12, 2008 | 11:07 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_zc &raquo;</TD></TR><TR><TD CLASS="quote">first off i have dohc zc and i know my timing is good i just check again what else could through a code 9 thanks for any help </TD></TR></TABLE>code 9 usually indicates that your exhaust camshaft timing is off - another thing that can cause it is not having the Cylinder sensor on the end of the exhaust camshaft wired correctly - another is bad Cylinder sensor, but that would be extremely, extremely rare - recheck your camshaft timing and the Cylinder sensor wiring - code 9 on a DOHC ZC has nothing to do with the distributor
Modified by jlicrx at 1:13 PM 8/12/2008
Old Aug 12, 2008 | 02:04 PM
jaywongwong's Avatar
Default Re: how to fix code 9 (jlicrx)
never had to deal with a code 9, but if jlicrx is on the right track this might help. the link shows you how to properly wire the dist and ex cmp sensor
hope this is helpful http://fourthgenhatch.net/zc.html#ZC
Old Aug 12, 2008 | 05:55 PM
ef_zc's Avatar
Default Re: how to fix code 9 (jaywongwong)
no to sound stupid but where is the cylinder sensor located
Old Aug 12, 2008 | 06:04 PM
jlicrx's Avatar
look 2 posts above yours
omgwtfbbqcrx
Jun 11, 2007 07:20 PM
89HTACH
22
Mar 20, 2004 04:53 PM
EF'n
Aug 20, 2002 01:11 PM
Cereal_Killer
Jan 25, 2002 01:52 PM
