fuel line, please help!
Old Aug 11, 2008 | 01:45 PM
jdmtp7's Avatar
Default fuel line, please help!
hey guys, im getting frustrated, 91 crx si, when i start my car after its been off for a few hours, i have to prime it 4-5 times by turning the key on and off, or it will just crank and not start. if its only been off for an hour or less it starts right up...
it is getting spark...
its obviously not getting enough fuel to the motor, i just dont know why. im thinking there could be a pin hole somewhere in the fuel line allowing it to suck in air? the tank was replaced recently before i got the car.
help please!
Old Aug 11, 2008 | 01:52 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: fuel line, please help! (jdmtp7)
your main (fuel pump) relay is probably bad. You can pull it out, test it, and resolder it to fix the problem with the part you have, or just buy a new one, which is more expensive than just repairing the one you have.
Old Aug 11, 2008 | 02:07 PM
jdmtp7's Avatar
Default Re: fuel line, please help! (sanimalp)
already replaced the main fuel relay.....
Old Aug 11, 2008 | 07:22 PM
sanimalp's Avatar
$cat /dev/urandom
a fuel pressure guage is what you need then.. Does it do it with a full tank of gas?
Old Aug 12, 2008 | 06:45 AM
acmoc's Avatar
mine does it when I'm on empty, but not when full. What does that mean?
Old Aug 12, 2008 | 08:53 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: fuel line, please help! (acmoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acmoc &raquo;</TD></TR><TR><TD CLASS="quote">mine does it when I'm on empty, but not when full. What does that mean? </TD></TR></TABLE>
No comment..
Old Aug 13, 2008 | 05:24 PM
jdmtp7's Avatar
it does it regardless how much fuel i have full 3/4 half and close to empty.....
im just out of ideas....
well i couldnt really come up with ideas to start....
bengal
Aug 9, 2006 08:50 AM
StraightCivic
Apr 24, 2006 03:58 AM
civic89si666
Jan 31, 2006 05:22 PM
nousername
13
Jun 17, 2003 10:28 PM
