92 accord hub/wheel stud question...?
Old Jul 22, 2002 | 08:01 PM
jarel's Avatar
Default 92 accord hub/wheel stud question...?
on my 92 accord...one of the wheel studs on the back rear hubs broke half-way off. does anyone know the size of the stock stud? should i replace the studs for the stock ones or just get some extended or aftermarket studs? any info would be greatly appreciated. thanks guys
Old Jul 23, 2002 | 04:20 AM
Charlie Moua's Avatar
Default Re: 92 accord hub/wheel stud question...? (chyknees)
stick with stock, unless you wanna go allout race with and accord. Just take it to tires plus they can do it in about 15min and only cost you about $25
[Modified by Charlie, 7:21 AM 7/23/2002]
Old Jul 23, 2002 | 08:21 AM
4doorH22's Avatar
Unless you need longer studs on all corners I'd just get a new stock stud from a local dealer. Should be in stock and just a couple bucks. Pretty easy to change yourself with some muscle.
Just remove hub, pound out broken stud, pound in new stud.
Old Jul 23, 2002 | 09:23 PM
jarel's Avatar
Default Re: 92 accord hub/wheel stud question...? (4doorH22)
thanks for the info guys....but do you know the measurement of the stud itself? cuase i picked one up at some auto store...and me and my friend plan to do it this weekend. thanks guys.
Old Jul 24, 2002 | 05:32 AM
4doorH22's Avatar
Well ummm uhhh can't you just go to a Honda dealer and spend a couple bucks for a proper stud and maybe forgo a #4 combo meal? You do have a Honda dealer around don't you?
Old Jul 24, 2002 | 05:33 AM
4doorH22's Avatar
As for the one you've got if the thread pitch is the same the length really doesn't matter. It certainly won't be too short and if it's too long it still shouldn't protrude from your lug nuts so it'll look normal when the lugs are on.
Old Jul 24, 2002 | 10:36 AM
jarel's Avatar
cool...thanks alot 4doorh22.
CarGuy91
Honda CR-V & Element
Apr 28, 2013 04:19 PM
piotrush
Honda Civic (2006 - 2015)
18
Jul 4, 2009 08:31 PM
timmy0tool
Oct 1, 2007 12:10 PM
jaxle
Jan 5, 2004 04:18 AM
Ludehrt
Aug 26, 2002 11:22 AM
