speedometer problem any help is helpfull
Old Aug 11, 2008 | 12:05 PM
norbs_crxsi's Avatar
Default speedometer problem any help is helpfull
i have an 88 crx si stock d16a6
when i hit the has no mater if its hard or crusing it, my mph nidle goes up and down, does not read correctly and when i let go of the gas they drop all the way to zero no mater how fast im going.
i could be going 80 then let go of the gas and they go to zero, then the moment i touch the gas pedle they go back up and down always around the 55mph.
ANY HELP IS GLADLY APPRECEATED.
Old Aug 11, 2008 | 12:09 PM
jooky5's Avatar
Default Re: speedometer problem any help is helpfull (norbs_crxsi)
I can only think of 3 things to check
1 the connection to the transmission
2 the cable
3 the speedometer
one of the 3 are bad. I'm thinking the cable is somehow broken and only spins the rest of the cable with the help of more power from the motor.
Old Aug 11, 2008 | 12:15 PM
Gus-Gus's Avatar
It's got to be some wiring problem.
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: speedometer problem any help is helpfull (jooky5)
Sounds plausible!
The inner cable may be broken, or binding in the outer cable jack.
Now my Speedometer squeaks are 30mph+... how do I 'lube' the cluster without having oil spit all over the inside of the cluster? I am going to try and cable lube the cable first....
Old Aug 11, 2008 | 12:24 PM
Default Re: (Gus-Gus)
WIRING PROB.?
HOW CAN IT BE A WIRING PROBLEM IF ITS A CABLE GOING INTO THE TRANSMISSION?
THNX FOR ALL THE FEEDBACK
Old Aug 11, 2008 | 12:35 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (norbs_crxsi)
See:
https://honda-tech.com/zerothread?id=1325930
Toward the bottom..
Old Aug 11, 2008 | 12:44 PM
Default Re: (88DXCRX)
I KNOW HOW DO TO ALL THIS IVE CHANGED THE TRANY OIL
IVE REGREASED THE CABLE
IVE DONE EVERYTHING POSIBLE AND NOTHING FIXES IT
IM THINKING IT MIGHT BE SOMETHING INSIDE THE TRANY
STILL THNX FOR ALL THE HELP GUYS
GPC91
Sep 17, 2012 01:11 PM
KhmerdudeSiR
13
Nov 12, 2008 01:52 PM
crxblues
Dec 6, 2006 10:44 AM
PA MATT
Apr 6, 2004 07:40 PM
drjondurst
Mar 29, 2003 06:34 PM
