will a jdm ep3 type r gauge cluster, plug into a usdm ep3
Old Aug 11, 2008 | 11:00 AM
sportinjected's Avatar
Default will a jdm ep3 type r gauge cluster, plug into a usdm ep3
saw a few online didnt no if any wring needed to be changed
Old Aug 11, 2008 | 12:54 PM
stealthep3's Avatar
Default Re: will a jdm ep3 type r gauge cluster, plug into a usdm ep3 (sportinjected)
yes
Old Aug 11, 2008 | 12:56 PM
stealthep3's Avatar
Default Re: will a jdm ep3 type r gauge cluster, plug into a usdm ep3 (stealthep3)
It is plug and play but you will lose the lighting behind the heater controls. There is a simple way to fix this (just cut and ground one wire) I just can't remember which wire atm.
Old Aug 20, 2008 | 11:33 PM
[Rob] *DC*'s Avatar
what about the itr cluster for a 04 rsx?just plug and play?
Old Aug 22, 2008 | 03:53 PM
johnclaunch's Avatar
Use the EDM cluster with the 160 mph speedo instead of the JDM model. The JDM has a slightly higher redline starting point (the max redline is the same) and a crappy 180 km/h (112 mph).
RoadRaceMike
Feb 24, 2011 07:03 PM
NosShootinHonda
Sep 4, 2009 05:31 PM
abolish415
Feb 5, 2005 01:58 PM
SpoonFed
Nov 15, 2001 08:22 AM
