Need Help LS swap
Old Aug 11, 2008 | 07:16 AM
hbombhondacrew's Avatar
Default Need Help LS swap
hey i have a hb that had the ls running in it will all si harnesses. my dumb friend spliced the harness all up when he did a ls vtec in another car. i bought a ls obd-0 harness will i be able to splice the two back together? like the injectors and other ramdon connectors he took off? or do i need to find a obd-0 si harness?
also when it is together i have a sleeved gsr block with type r pistons b16 head with p1 valves and all the trimmings how do i convert the obd-0 to obd-2 because i think the distributor, intake manifold, and throttle body were of a obd-2 head. not too sure though it might be obd-1
Old Aug 11, 2008 | 07:18 AM
Default Re: Need Help LS swap (hbombhondacrew)
i forgot the ls has a obd1 alternator (green connector) that was already spliced and worked
Old Aug 11, 2008 | 09:12 AM
black0hatch's Avatar
if i were you i would just get another clean si harness. you can take the plugs off the teg harness and splice them into the stock harness but you cant plug in the teg harness to the car. obd0 and 0bd1 have the same alternator plug. and you really should convert the other motor to obd1 you need to buy a jumper harness for that.
hatcht9x
12
Sep 7, 2025 10:49 PM
toolbox21
Jun 12, 2012 09:50 AM
JDM EJ1 95
Mar 20, 2010 07:12 AM
hYbRid_Eg6
Apr 16, 2009 09:44 PM
WrongWD
Feb 10, 2005 01:06 AM
