best B16 cams for my $
Old Aug 11, 2008 | 07:03 AM
bird00420's Avatar
Default best B16 cams for my $
hey all, i have the b-series swap in my '89 hatch & was looking to get a nice set of either stage 2 or stage 3 N/A cams to make my motor more aggressive. i have header, exhaust, intake manifold, throttle body, cold air intake, new: stage 3 ported & polished head, ferrea valves, 11,000 RPM dual valve springs, viton seals, upgraded retainers, and rockers. i was wondering if anyone could help me out & point me out in the right direction any help or suggestions would be GREATLY appreciated oh yeah, my springs are good for 16.5mm (0.6496") of lift
Old Aug 11, 2008 | 07:36 AM
bird00420's Avatar
Default Re: best B16 cams for my $ (bird00420)
bump 4 moving my thread
Old Aug 11, 2008 | 08:09 AM
mar778c's Avatar
Community Builder
Community Influencer
I don't know about best or even your goals but I seen very good results with s2s2.
Old Aug 11, 2008 | 08:56 AM
bird00420's Avatar
Default Re: best B16 cams for my $ (mar778c)
thanks im trying to maximize my HP without sacrificing my low/mid ranges. i know that certain high lift cams require minimum compression ratios of like 12.5:1 or whatever, but my compression ratio is kind of a mystery since i have dished ferrea valves & have a single layer gasket im thinking my compression'll be around 10.5:1 or maybe a lil lower? do you know anything about the crane stage 2/3's or the crower stage 2/3's?
Old Aug 11, 2008 | 10:39 AM
QuickDxEk's Avatar
I think you would have good luck with the skunk 1s. Im getting ready to Jdm itr pistons and a thinner gasket also. The rings seem to be leaking a little. With skunk1s and bolt ons, i daily drive it, and still pushes my coupe to 14.50.
Old Aug 11, 2008 | 11:09 AM
bird00420's Avatar
Default Re: (QuickDxEk)
i was looking into the buddy club spec III plus cams
Old Aug 11, 2008 | 02:15 PM
UncleD's Avatar
Default Re: (bird00420)
Is UGR still around? Check out their "Jun3/S2S2/BloxB/BloxC," or for a better midrange - BC3+.
iamthefollower
May 25, 2012 03:05 PM
carlossolorzano
May 18, 2012 04:38 PM
93b16CivicSi
10
Jun 8, 2005 05:37 PM
vtecgod
Jul 26, 2003 09:20 AM
