GOT RIPPED OFF!!
Old Aug 11, 2008 | 06:48 AM
stevew84's Avatar
Banned
Default GOT RIPPED OFF!!
i actually do have a question but i need to explain first.
two days ago i traded an EK for a 94 GSR teg but the ecu in the car was for a non vtec motor so that is garbage now. i was telling myself to buy the P72 ecu because it has the IAB and Knock senor compatibility.
i was looking around craigslist.com and found a guy selling a bunch of electronics for tegs and civics and he said "no bro you need a p28". i bought the damn thing for $100. it looks brand new i mean in very good shape but after doing some research, i see that this does NOT support IAB or Knock.
im not a street racer and dont really care if i have the crazy *** vtec high speed blah blah blah, BUT the ecu i had was for an automatic 92-95 single cam non-vtec. with that being said, my RPM's were fluctuating and would sometimes die out when i pop it out of gear and press the brake (the rpm gauge would go to zero instantly and die out going about 50mph).
bottom line is this, will i have an at least "decent" running GSR? i know i can get the p28 chipped but im not experienced with that. or should i try to sell this and pick up a p72?
also the guy i bought the ecu from told me that you can infact hook up the knock and IAB to the p28 to get everything working correctly.
any help would be appreciated!!
steve
Old Aug 11, 2008 | 07:15 AM
cetcivic's Avatar
no one wants to hear the truth
Default Re: GOT RIPPED OFF!! (stevew84)
find a reputable shop in your area that does tuning or ecu chipping and get the p28 chipped w/ a gsr basemap.good luck
Old Aug 11, 2008 | 07:21 AM
stevew84's Avatar
Banned
so i pretty much am screwed right? i mean it will run better than with the P05 that i have in there now, 92-95 automatic single cam non vtec
Old Aug 11, 2008 | 07:52 AM
jonshonda's Avatar
Community Builder
If you don't plan to do any future tuning, then just get a P72 and call it a day!!
Old Aug 11, 2008 | 08:55 AM
Slomies's Avatar
just buy a p72 anyways ...
Old Aug 11, 2008 | 09:04 AM
Neptronix's Avatar
Default Re: (Slomies)
seriously. get the right friggin' ecu.
be lucky you didn't get ripped off on an entire car.
Old Aug 11, 2008 | 09:23 AM
AlphaQup's Avatar
The P28 will work, as long as it's chipped and modified for MT. Since you have no experience and seems like your the the type of person who wouldn't be interested in learning, just get a P72 and sell your P28 to me for 10 bucks.
Old Aug 11, 2008 | 09:28 AM
stevew84's Avatar
Banned
the p28 is a manual ecu
Old Aug 11, 2008 | 09:37 AM
AlphaQup's Avatar
Default Re: (stevew84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">the p28 is a manual ecu</TD></TR></TABLE>
Dude, there ya go! Even better! I ran my 98 GSR motor on a chipped p28 auto (converted) ECU. Just get it chipped and run a GSR basemap (for now) using CROME or UBER (freeware). In the future if you do decide to add on performance parts to your motor, you can always have it tuned/retuned.
Go here and read up if you want to learn: http://forum.pgmfi.org/
Old Aug 11, 2008 | 09:39 AM
stevew84's Avatar
Banned
while im still not entirely comfortable with the situation, hondata has ecu's listed based on desirability, or i guess whats most commonly used or "best". for the 94-97 b18c1, which i am running, it shows p72/p28.
so i guess i should be fine with this for now, and i'de like to chip it eventually
Old Aug 11, 2008 | 09:48 AM
Horseofcourse's Avatar
if you keep running a P28 without a chip and basemap you will ruin your motor fast. end of story. Get it chipped or get the right ECU hondata lists that because you can put a hondata in a p28 and run a gsr perfectly but the stock p28 is garbage in a DOHC espicially if your running the stock GSR intake manifold. Dont ruin your car over something so easy to fix
Old Aug 11, 2008 | 09:57 AM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">while im still not entirely comfortable with the situation, hondata has ecu's listed based on desirability, or i guess whats most commonly used or "best". for the 94-97 b18c1, which i am running, it shows p72/p28.
so i guess i should be fine with this for now, and i'de like to chip it eventually</TD></TR></TABLE>
Hondata is fine, but more money you'd have to fork out to get the hondata unit. Just get your p28 socketed and you can easily obtain a chip with a GSR basemap if you really looked. PM me if you want.
If you're planning on running the stock p28 on your GSR motor, I wouldn't recommend it. Do it right and you wont have any problems in the future.
Old Aug 11, 2008 | 02:14 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (AlphaQup)
PM IH8RICERZ
He can hook you up with a chip and could even socket the ECU for you.
Old Aug 11, 2008 | 02:30 PM
stevew84's Avatar
Banned
ok, thanx. i talked to the guy i got the teg for. he said he has an ls/vtec (thats the swap thats in the teg) chip that was custom programmed. he will sell it to me for $70 AND de-solder and re-solder the ecu.
unfortunately i can only take his word on the chip. it could be blank for all i know. cant read it until its soldered on.
anyone ever have a leaky fuel filter on a gsr before? mine is leaking i BELIEVE from the fitting (directly on top of the filter). i think this line runs back to the tank? let me know if im wrong, also the fuel rail line is tight.
Old Aug 11, 2008 | 03:26 PM
Dogginator's Avatar
Daisy... Daisy...
The IAB can be operated with a simple RPM switch.
Old Aug 11, 2008 | 03:44 PM
94gs-r's Avatar
Just chip it and make it run better then stock.
Old Aug 12, 2008 | 06:33 AM
stevew84's Avatar
Banned
update: plugged in the p28 and man its a difference like night and day.
the car idles at 1000rpm now, doesnt fluctuate while driving (does in the morning tho) and the vtec hits like a son of a bitch.
vtec engages at what i think is either 5000-5500rpm. with my stage 2 clutch and Fidanza flywheel im hittin 85-90 in 3rd and still going, i havent been able to get into 4th gear yeat while driving agressive. economically yes haha
Old Aug 12, 2008 | 07:35 AM
gibsanez's Avatar
Are you ripping around on the stock P28? Or the chipped one?
Old Aug 12, 2008 | 08:38 AM
stevew84's Avatar
Banned
stock until the 22nd, im getting it chipped then.
Old Aug 12, 2008 | 09:29 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevew84 &raquo;</TD></TR><TR><TD CLASS="quote">stock until the 22nd, im getting it chipped then.</TD></TR></TABLE>
Honestly you shouldn't be tazzing on the car right now, considering the ECU thinks it's fueling a 1.6 single cam.
RiceOrRocket
Aug 28, 2007 09:13 PM
qazaq
Nov 28, 2006 11:42 AM
streetlvlhatch
Mar 17, 2004 05:50 PM
Forrest Gump 9
Aug 26, 2003 06:39 AM
C4wrx
Mar 6, 2002 04:59 PM
