Needing some part numbers...
I recently did a swap for a buddy of mine...full b18b1/5spd swap out of a '94 Integra LS in to his '92 Honda Civic CX hatch-back.
Swap went perfect until I got to the front lower mounts. The rubber ends were demolished, so I bought new ones. I attached the front lower mounting brackets to the motor, since it's in the civic already, and to make it easier to remove what I thought was just a bolt holding the rubber end piece to the mounting bracket. Turns out it's just a double-sided stud...one end threads into mounting bracket, other end goes through rubber mount and receives a washer/bolt on the end. I can not get that nut off the stud, trashed two pairs of vice-grips...tried a torch and penetrating oil...tried heat and wax...nothing. I decided to just toss those old rubber mounts with the studs/nuts still on them and buy new studs/nuts/washers for the new rubber mounts I already purchased...but I need acura part numbers.
Below is a link to a blown-up parts diagram from a '92 civic cx, not a '94 integra ls...I'm using this picture as a reference only.
http://slhondaparts.com/images...1.jpg
#17 + #18 + #32 + #34 are what I need, but for a '94 Integra...not the Civic, since I need to use pretty much everything from the Integra for the swap. I am not sure if these nuts/bolts/washers are the same between cars. If they are, I can just order from slhondaparts and save myself the trouble of calling/visiting Acura.
Any info is greatly appreciated. Gotta get this car done as soon as possible, and this is the only thing holding me back.
Did some google searching and answered my own question.
http://www.acuraautomotivepart...ormal
I've not only bookmarked this site, I also have it written on a post-it note and stuck to my desk.
socialistic
10
Jun 11, 2008 12:20 AM
floyddan7
Aug 25, 2003 06:33 PM
