Best header for ls/v-tec in crx
Old Jul 22, 2002 | 07:03 PM
DTAYLOR's Avatar
New User
Default Best header for ls/v-tec in crx?????
What header fits the best for ls/v-tec in crx with hasport mounts? I have the LS oil pan. Trying to keep it close as I can to the motor. Thinking about DC just need to know what one to get.
[Modified by DTAYLOR, 11:16 PM 7/22/2002]
Old Jul 22, 2002 | 07:33 PM
Pelican's Avatar
Default Re: Best header for ls/v-tec in crx????? (DTAYLOR)
The DC sports JDM Type R one works well, I think. Especiallt for what its modelled after. Allthough the flanges are different, and you would have to do cutting/welding to get them to match up to the rest of the exhaust..
Old Jul 22, 2002 | 07:37 PM
DTAYLOR's Avatar
New User
Default Re: Best header for ls/v-tec in crx????? (Pelican)
Sold my exhaust with the old motor that was in the car
Old Jul 22, 2002 | 08:50 PM
Pelican's Avatar
I just mean the flange is funny. If you're getting/fabricating a new exhasut, hell, I'd recommend it. The 4-1's are gonna stick out a tiny bit lower than the 4-2-1 but I like mine.
Old Jul 22, 2002 | 11:55 PM
.Ryan's Avatar
Don't Trust Anyone
http://www.importbuilders.com modded JG 4-2-1 2.5" collector header
Old Jul 23, 2002 | 03:57 AM
DTAYLOR's Avatar
New User
thank's for the info. What about using a ls header? Would it fit closer to the oil pan?
Old Jul 23, 2002 | 04:25 AM
Charlie Moua's Avatar
the best???? Hytech-$1300 or Toda-$950
best as in not srapping on the bumps----- stock.
Old Jul 23, 2002 | 06:59 AM
dohcsideSi's Avatar
you can use an ls header, but i would go w/ a jdm 4 into 1 or the dc jdm header
Old Jul 23, 2002 | 07:04 AM
EF_LSVtec's Avatar
Default Re: Best header for ls/v-tec in crx????? (dohcsideSi)
I'm using a JDM 4-1 header and as long as you put a shield then its not too bad. Top end power is really noticeable..
Old Jul 23, 2002 | 07:09 AM
spettinger's Avatar
Default Re: Best header for ls/v-tec in crx????? (EF_LSVtec)
the jg header is not worth the money in my opinion, that is a lot of money for something with a little 2" collector. also, going into an EF, you will have to cut off the front of the flange on the manifold/ downpipe joint to avoid completely cutting your front crossmember any further. i would do a JDM DC 4-1 with the 2.5" collector, and a 2.5" exhaust all the way back. go custom and just use a magnaflow or whatever muffler in the stock configuration. very nice top end power.
Old Jul 23, 2002 | 09:58 AM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Best header for ls/v-tec in crx????? (wreckedhatch)
Ya SMSP, TODA, HYTECH are great.
And BTW...the http://www.imporbuilders.com MODDED JG header with a 2.5" Collector makes more power than a ITR header/DC "JDM" header.
[Modified by SpoonSportsEF7, 6:59 PM 7/23/2002]
Old Jul 23, 2002 | 11:31 AM
shortysdohdoh's Avatar
I think you should read up on some of the headers man. In the one of the Super Street mags, they did a header test. you should check it out, i don't know what issue it was or if it was the Sport Compact Car mag., but i don't think they were lying. Anyways, some of those headers had an overall gain of NEGATIVE horsepower, with DC being the best overall, comparing to the stock manifold. Mugen i think had the best top end but overall wasn't so good. go with your
Old Jul 23, 2002 | 01:14 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Best header for ls/v-tec in crx????? (shortysdohdoh)
http://www.importreview.com/performance.html
Its up to you man, but the 4-1 headers hang low on "EF's". So if you dont mind scrapping that money away get a 4-1.
[Modified by SpoonSportsEF7, 10:16 PM 7/23/2002]
Old Jul 23, 2002 | 03:24 PM
DTAYLOR's Avatar
New User
Default Re: Best header for ls/v-tec in crx????? (JDMhondaslut)
my car is low and I drive it on the street and use it alot for track events. Trying to keep it up high as I can. Also beating the front crossmember up does not sound real cool. Going to but the motor in it this weekend so I should get a better idea how much room I have.
I3lakeintegra
May 5, 2013 11:02 AM
squeezedeghatch
Feb 18, 2009 02:03 PM
Zatzy
Oct 18, 2005 10:44 PM
h22a193
Oct 3, 2003 01:24 PM
civickiller
15
Jun 18, 2003 11:33 AM
