just replaced clutch and now...
If you bleed Twice, it should have some pressure. Did you pump out five times and bleed????? You someone pump the pedal and you are bleeding the slave cylinder, you should see the slave cylinder pushing out the braket.
To answer your questions, it is not normal. Check for leak at the master cylinder too.
T"u"Rtle
Apr 21, 2006 10:17 AM
JoJO...
10
Sep 30, 2005 08:56 AM
