charging problems..???b16a
Old Aug 10, 2008 | 11:40 AM
vw eater's Avatar
Default charging problems..???b16a
hello thanks for looking at my post, i have a 91 crx si w/b16a and my charging voltage is 12.8 @idel and if i rev it up a lil it jumps to 14.5 is this ok?i have a couple subwoofers and at night the audio set up draws a lot of power and dims the lights while iam driving.
Old Aug 10, 2008 | 12:51 PM
dlaub25's Avatar
Default Re: charging problems..???b16a (vw eater)
That seems to be normal. My rex sits a little above 13 at idle and jumps up to 14.x when i tap the throttle. I am running an average sized amp to 4 component speakers. Also I read in my shop manual that the crx also has a circuit that drops the output voltage under certain conditions. I believe it had something to do with economy.
Old Aug 10, 2008 | 03:32 PM
vw eater's Avatar
is there a way to bypass that circuit, so its always charging 14+?
Old Aug 10, 2008 | 06:11 PM
Crx Jimmy's Avatar
Default Re: (vw eater)
its just that during idle it really doesnt spin the alt enough. The easiest way to go about it is to put a larger crank pulley like a b20 to overdrive it or just raise the idle to 1,200 or so
Old Aug 11, 2008 | 04:52 AM
dlaub25's Avatar
Default Re: (Crx Jimmy)
Im pretty sure that it only is in effect at cruising speeds.
Old Aug 11, 2008 | 06:09 AM
Eaglekper0046's Avatar
Get yourself a capacitor, or a optima battery, or a larger AMP alt.
Old Aug 11, 2008 | 07:14 AM
vw eater's Avatar
Default Re: charging problems..???b16a (Eaglekper0046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 &raquo;</TD></TR><TR><TD CLASS="quote">Get yourself a capacitor, or a optima battery, or a larger AMP alt.</TD></TR></TABLE>
i did all that, i have a 160 amp alt, a red top and a 2 farad cap, and it still dims the lights all crazy, i have 2 w7's and a 1000/1 and a 300/4 amp...
Old Aug 11, 2008 | 07:22 PM
vw eater's Avatar
i had a buddy check his charging system and it read 14.5 while at idel....do you guys have that reading ? his was a stock 89
Old Aug 13, 2008 | 12:02 AM
vw eater's Avatar
bump
Old Aug 14, 2008 | 08:07 PM
vw eater's Avatar
does anyone know there charging voltage @ idel?
Old Aug 24, 2008 | 09:25 AM
vw eater's Avatar
Old Aug 24, 2008 | 09:31 AM
autowrench07's Avatar
your dimming lights isnt because of your voltage level it has to do with your amprage...how do u have everything wired? if you dont have i wired right you can have 12 batteries and it wont do ****
Old Aug 24, 2008 | 02:22 PM
traxxasx's Avatar
Default Re: charging problems..???b16a (autowrench07)
I would do the big three.
Should help ALOT!.
http://www.the12volt.com/insta...~PN~1
Old Aug 24, 2008 | 04:11 PM
vw eater's Avatar
Default Re: charging problems..???b16a (traxxasx)
i have it wired from the battery, someone told me that if you have it connectd from the battery the eld dosent see the load?is this true?i did put 0 guage on my battery and on the ground and the alt, i dont have one on the transmission i will add a 0 guage ground there..thanks for the help guys
Old Aug 25, 2008 | 10:35 AM
vw eater's Avatar
bump
Old Aug 25, 2008 | 10:52 AM
SIred91's Avatar
Rainman
No offense meant, but, CLEAN YOUR BAY.....GO TO THE CAR WASH AND CLEAN THAT UP!!
gross. I would worry about that before my lights dimming while trying to out techno the volkswagon at the stoplight.....
Old Aug 25, 2008 | 11:00 AM
vw eater's Avatar
Default Re: (SIred91)
verry true i need to clean it up it looks like $hit.. and techno is for quers i just ''bump'' the country
Modified by vw eater at 1:07 PM 8/25/2008
Old Aug 25, 2008 | 12:02 PM
sinepome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vw eater &raquo;</TD></TR><TR><TD CLASS="quote">
verry true i need to clean it up it looks like $hit.. and techno is for quers i just ''bump'' the country</TD></TR></TABLE>
hahaha that's going into my sig.
get a deep cycle battery. ones for boats and stuff, they draw the power out differently or something. i had a celica with one and also had 4, 15's in it once and the lights never dimmed ever.
Old Aug 25, 2008 | 12:09 PM
vw eater's Avatar
Old Aug 26, 2008 | 08:57 PM
vw eater's Avatar
help....
Old Aug 26, 2008 | 11:24 PM
DCRB's Avatar
nice subs... what i did in my van to stop the dimming of the lights (two phoenix gold octain R 10d subs in a ported box pushin 400+watts per sub, wired in parallel VC so it's runnin @ 2 ohm, plus a 4ch amp to the speakers) was i added a kinetic battery to my charging system. it's the equivalent to 200+ farads. never had a problem since. and trust me, my stuff would dim WAY down when i was drivin at night. i also upgraded my alt power wire from 10g to 4g. helped alot
Old Aug 28, 2008 | 12:32 AM
vw eater's Avatar
yea i might have to do that...add 1 more battery
MichaelCRX
Feb 3, 2014 04:18 AM
cujo613
Audio / Security / Video
15
Aug 10, 2007 10:18 AM
dylokjai
May 8, 2007 11:11 AM
Flow
Nov 4, 2005 07:43 AM
