time for new brake discs
Old Aug 9, 2008 | 08:47 PM
tweek_boii's Avatar
Default time for new brake discs
like the title says. what are benefits from drilled disks? and what else do i need to buy. i have a gsr, i would want to do a big brake conversion but my budget is low. most i will spend is 200 on brakes .. for now
Old Aug 9, 2008 | 09:16 PM
khurrum's Avatar
slotted/drilled disk brakes help reduce friction and dissipate heat quicker than conventional rotors.
tirerack.com is pretty reasonable for a budged brake job while still offering tons of perfomance partts. i just finished my brake job on my DA. cost with shipping was like 370 for front disks/pads , and rear disk/pads.
cheers
Old Aug 9, 2008 | 09:18 PM
khurrum's Avatar
ooh just read the rest of your post, you will need to buy: depending on the condition of the current parts:
brake disks
pads
lube
brake cleaner
brake lines (steel braided works better for performance cars)
calipers
and bleed your brakes so you will need brake fluid.
Old Aug 9, 2008 | 09:43 PM
tweek_boii's Avatar
Default Re: (khurrum)
dang ima take it to a shop sounds complicated. but ima check that website
johnwohl
Jun 27, 2010 08:52 PM
R.a.w.
Feb 10, 2006 08:29 PM
integra714
Sep 17, 2004 10:29 PM
Ninja Mike
May 27, 2004 07:20 PM
