correction: torque specs of Eagle rods for b18c1
Old Jul 22, 2002 | 05:33 PM
b00stedbyFastrax's Avatar
Default correction: torque specs of Eagle rods for b18c1
what are the torque specs for the b18c1? with moly lube and motor oil. i know that the stock rods are 33 ft/pound.
Old Jul 24, 2002 | 12:12 PM
X-Mazda 3 Racer's Avatar
Default Re: correction: torque specs of Eagle rods for b18c1 (BoostedbyFastrax)
The correct torque specs for Eagle rods on a B18C1 is 28 ft. lbs. using the ARP moly lube. You should use nothing but this lube for correct torque. Over-torquing the bolt will weaken it causing failure. Make sure it is ARP moly!!!!
dingusjt
Feb 6, 2015 08:59 AM
sscivicsi
Jun 29, 2008 05:43 PM
allanonjj
Jan 12, 2008 10:55 AM
b00stedbyFastrax
Dec 27, 2002 03:35 AM
b00stedbyFastrax
Jul 25, 2002 09:24 PM
