GSR Hatch build up, from the begining..
Old Aug 9, 2008 | 02:02 AM
GSR-EG-92's Avatar
Default GSR Hatch build up/all motor build
Plans:
JDM GSR swap
Bottom end re-build
Modded GSR intake-no secondary system
B16 trans
Wire tuck
Interior semi-gut
Exterior/interior mods
Painted it red a few days later and it didnt look too bad.
Radiator sprung a leak (white **** all over the dizzy and hoses) and the motor overheated on the highway, didnt realize untill I saw smoke coming from the hood, nothing got damaged though
New all aluminum, no more plastic junk..
Another issue, shifing a little too hard I think..
Got a new Skunk2 weighted **** and Type-R boot, man the weight of the new unit is nice.
Bought an H-brace and threw that on..
I felt it was time to spend some real money on the car and get the suspension taken care of before anything else major, so I did the rear trailing bushings.
The tool was amazing, thanks to the guys at turbod16.com for renting it to me.
Skunk2 Pro+ front camber kit, just make sure you locktite the allen bolts that adjust the plate or they may fall out on the highway on your way to work in the morning and almost kill you.
Function 7 LCAs, I get alot of heat about dropping the cash on these, but hey, I like them lots.
Koni and GCs, 550 in the front and 500 in the rear, may go stiffer in the future!
Wheels and tires..
The monster, before I sold it and got a JDM GSR lol.
The old
The new WS2, imo one of the best sounding out there.
One more pic of the old very tired Z6 with 288,000 kms on her.
Working on cleaning the interior..
Thought Id tak the head off and check it out, not bad.
Axles nuts coming off, $19 socket for God sakes!
No more PS and tucking harness
Pet Flexo'd harness...
Lots more to come.
Modified by GSR-EG-92 at 3:10 AM 8/9/2008
Modified by GSR-EG-92 at 11:13 AM 8/9/2008
Modified by GSR-EG-92 at 7:33 PM 8/31/2008
Modified by GSR-EG-92 at 10:50 PM 10/3/2008
Old Aug 9, 2008 | 03:15 AM
jdmpnoy89's Avatar
Default Re: GSR Hatch build up, from the begining.. (GSR-EG-92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR-EG-92 &raquo;</TD></TR><TR><TD CLASS="quote">
be sure to bolt up that ground box to the chassis
looks like a good start
Old Aug 9, 2008 | 08:56 AM
GSR-EG-92's Avatar
Ya, I have to go back and do that today, I was wondering if anyone would spot that haha
Old Aug 9, 2008 | 09:15 AM
JdelMsolG's Avatar
Default Re: (GSR-EG-92)
nice. keep em comin.
Old Aug 9, 2008 | 09:52 AM
GSR-EG-92's Avatar
Hey does anyone know why my JDM H22A throttle body is SMALLER then my JDM B18C?
I thought the H22A was 62mm and the B18C was 60mm but its backwards it seems??
I was also going to change out the B18C injectors for the bigger H22A injectors but I think I would need a resistor box for them.
Old Aug 21, 2008 | 04:15 PM
GSR-EG-92's Avatar
New stage 1 clutch and 7.5lb flywheel, I've heard its not the best brand but I plan on boosting in the next year so I will need a new clutch anyway, should be fine for a stock motor with bolt-ons.
In total, 12lbs less then stock wheels thats all 4 combined
The harness still needs work, I wanna Felxo Pet the entire unit
CTR N1 crank pulley, from what I have read it likes to shatter oil pump gears? Toda cam gears coming
As it looks now, I have to keep the motor in the engine bay because I am not allowed to have "parts" "laying around". I NEED A TRANS! ANYONE HAVE ONE?
Newly coated...
Going on month number 4 of this swap.
SELL ME A TRANSMISSION
Modified by GSR-EG-92 at 5:28 PM 8/21/2008
Modified by GSR-EG-92 at 2:27 PM 10/22/2008
Old Aug 21, 2008 | 05:22 PM
Cole D's Avatar
what wheels are those what size 15s?
Old Aug 21, 2008 | 07:27 PM
GSR-EG-92's Avatar
Ya 15" Rota Grid
Old Aug 21, 2008 | 08:07 PM
mfef4dr's Avatar
nice
Old Aug 21, 2008 | 09:47 PM
low91rex's Avatar
Default Re: (mfef4dr)
Damn nice, I wish I had cash like that to drop on my junk. one day. Keep it up mang
Old Aug 21, 2008 | 11:40 PM
Nor Cal's Avatar
Default Re: (low91rex)
seriously... hes throwin down some paper...
Old Aug 22, 2008 | 12:00 AM
skipunk4's Avatar
Default Re: (Nor Cal)
Damn sweet build up. Im glad to see you got rid of the h22 and got the gsr. Nice choice
Old Aug 22, 2008 | 04:44 PM
GSR-EG-92's Avatar
Thanks guys, this **** is my pride and joy, I dont smoke or drink so the money has to go into something lol
Old Aug 23, 2008 | 11:00 AM
PSU's Avatar
PSU
formerly DxHatchback
Dang, that is one clean hatch.
So lucky.
Old Aug 31, 2008 | 06:54 PM
GSR-EG-92's Avatar
Default Re: (DxHatchback)
Well I have a little more down time with the car so I thought it would be nice to get the bottom end taken care of so I dont have to rip into it later on.
Input is welcome...
We have 94 octane up here at most pumps so Im thinking of playing with the compression calculator and getting something around 12:1.
PCT's are kinda high, so maybe P30's? What do you guys think?
I may buy some light weight I-beam rods also.
Disassembly
Off to the shop..
Old Aug 31, 2008 | 09:49 PM
JDMDC2BOY12's Avatar
wow
Old Sep 1, 2008 | 02:21 PM
American.Graffiti's Avatar
Going hard on the suspension I see. Nice to see that being an initial point of focus.
Old Sep 2, 2008 | 12:50 AM
GSR-EG-92's Avatar
Ya, the suspension was first on the list for me. Like we always hear, no point in making power if you cant get it to the ground.
SMALL UPDATE:
I took care of a couple things that needed a good clean (lots more parts to do)
Before
After
Alternator was really dirty
after
more to come...
Old Sep 18, 2008 | 07:39 PM
suno's Avatar
What did you use to clean all the dirt and grease off the parts?
Old Sep 29, 2008 | 08:12 PM
slow_eg6's Avatar
i want to know too...
Old Sep 30, 2008 | 01:28 PM
crxd88's Avatar
Default Re: (slow_eg6)
It's a good build so far. Watch out for that seal on the coolant tube lube it up before you insert that back into the motor.
Old Oct 1, 2008 | 11:49 AM
Updates!
Old Oct 3, 2008 | 10:03 PM
GSR-EG-92's Avatar
Default Re: (crxd88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxd88 &raquo;</TD></TR><TR><TD CLASS="quote">It's a good build so far. Watch out for that seal on the coolant tube lube it up before you insert that back into the motor. </TD></TR></TABLE>
Thanks for the info man, its little things like this stuff that help out.
As for the other question, I used a wire brush bit and drill to get the parts looking normal again.
I have been working very hard to pay for the rest of the parts and get this damn thing back on the road, so the next 3 weeks will have lots of updates motor should be in my the end of the month.
I FINALLY GOT MY HANDS ON A B16A2 TRANS! Its taken long enough, I looked at 6 or 7 of them before I bought it. Should be here next tuesday and Ill post pics.
Okay, here are the slugs, PCT (B16B) 81.50mm, 94 octane here I come! And some ARP rod bolts.
Modified by GSR-EG-92 at 11:12 PM 10/3/2008
Old Oct 7, 2008 | 07:32 AM
suno's Avatar
Hey did you have to use Integra shifter linkages? Does it have to be from a GSR?
I'm doing the same install in my coupe right now.
Old Oct 7, 2008 | 08:53 AM
Basskika's Avatar
Banned
Sweet build buddy .. Looking forward to seeing this finished!
