engine light
for the last couple weeks, my engine light been going on. it's pretty random too. some nights it'll go on while other nights it'll be fine.
i recently changed my spark plug seals, yesterday actually.
while i was driving back on the freeway, just hitting 70-75 the engine light came on for the last 5 or so minutes of my ride. no idea why. just would like a bit of opinion. k thnx. live in the bay too if anyone wnats to help a brotha and take a look.
Check you're code on the ECU. Lift up the carpet on the passenger side to find a blinking light. Then look in a manual or online to see what the code is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by telekineticz »</TD></TR><TR><TD CLASS="quote">say the engine light doesn't go on for awhile, will it blink with the problem otherwise or onlyw hen the engine light goes on?</TD></TR></TABLE>once the ECU detects an apparent problem and triggers the Check Engine Light, the code will remain stored in the ECU until you reset the ECU - the CEL will go off when you turn off the ignition and won't come back on until the ECU senses another (or the same) problem - sounds like you may have a problem with the oxygen sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by telekineticz »</TD></TR><TR><TD CLASS="quote">is it the red flashing light? or do i have to take the cover off and pull the whole ecu out to find a different light?</TD></TR></TABLE>
Yes its the red flashing light. just count the flashes.
alright, just went out for a 20 minute drive; street and freeway hoping my light would come on so i could check the ecu. yet again, the light decided not to go on... like it does randomly. will come on sometimes while other times it'll stay off for a few days. i'm thinking it's the oxygen sensor. diagnose my problem. PLEASE!!!
up!
up!
so i finallly caught my engine light. there was one blink.. then like 2-3 second pause of no blinks.. then another... and repeat. so i'm guessing that is just code 1 since there were no constant blinks. thats my oxygen sensor then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx »</TD></TR><TR><TD CLASS="quote">Yes sir you need a new o2 sensor.</TD></TR></TABLE>
thanks trax!
thanks trax!
pindented
Jul 11, 2013 11:07 AM
