fuel line help
Old Aug 8, 2008 | 08:21 PM
TegraD's Avatar
Default fuel line help
whats the easiest way to fix a cut fuel line. its the pressurised line that leads frm the bottom of the fuel filter to the fuel pump. one side in front of the gas tank is cut and one right infront of the fire wall... whats the easiest way to fix this? please help
Old Aug 9, 2008 | 07:54 AM
blkb18's Avatar
Default Re: fuel line help (TegraD)
You should replace the line, oem lines are a bitch to do, being they are prebent and are very hard to manipulate. You may be better off buying a roll of tubing and some fittings and flaring your own line. The tubing is much softer and easier to fish through the tight spaces. You could repair the existing line with compression fittings, but its not reccomended.
Old Aug 9, 2008 | 02:06 PM
TegraD's Avatar
Default Re: fuel line help (blkb18)
why arnt the compression fittings recomended? do you know? and someone told me if i used rubber tubing to tie them together it would be alright... is this true? or would it even work...if i clamped the crap out of them...
Old Aug 9, 2008 | 04:29 PM
blkb18's Avatar
In a perfect world the compression fittings or soft line will be fine. The reason they are not reccomended is because its not a perfect world. If something in the road is kicked up and strikes the line it could leak, if the fittings arent done right or if the soft line clamps weaken over time they could leak. An engine bay leak is what is most dangerous. I have used compression fittings with brake lines, and it works fine, and brake line pressure is much higher than fuel line pressure. One solid line is just the better way to go, especially with the pressure line.
Old Aug 10, 2008 | 09:01 AM
TegraD's Avatar
damn this imperfect world... ha but thanks mna, i appreciate it... now i have to go change the whole line... thanks again...
dmotoguy
Mar 2, 2008 10:27 AM
JLefevers
Jan 1, 2008 09:20 PM
tcfsurfer
Mar 30, 2006 06:26 PM
LVHonda
Feb 13, 2005 06:58 PM
IMSTOCK
Aug 23, 2004 08:46 PM
