hondata boost control solenoid
Old Aug 8, 2008 | 04:50 PM
GReddy_Civic's Avatar
Default hondata boost control solenoid
I know the solenoid gets hooked into a 12V and the ECU A11, but is that the A11 on the ECU or the wiring harness...and also, how do I attach the wire to it?
Old Aug 8, 2008 | 04:54 PM
Default Re: hondata boost control solenoid (GReddy_Civic)
do I splice the A11 wire?
Old Aug 8, 2008 | 10:34 PM
mtber's Avatar
A11 at the obd1 ecu pinout.
Old Aug 9, 2008 | 08:46 AM
Default Re: hondata boost control solenoid (mtber)
Does the wire from the conversion harness get removed then? Because there is a wire running from the conversion harness (obd2a) that runs into that pin
Old Aug 9, 2008 | 11:06 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy_Civic &raquo;</TD></TR><TR><TD CLASS="quote">Does the wire from the conversion harness get removed then? Because there is a wire running from the conversion harness (obd2a) that runs into that pin</TD></TR></TABLE>
No, the wire & pin stays in the obd1 side of the obd1 plug. You are running a11 directly to the solenoid.
Old Aug 10, 2008 | 06:03 AM
Yea, someone on turbod16 told me to splice the wire on the harness going in to the A11 pin with the boost control solenoid wire. Thanks
Old Aug 10, 2008 | 06:22 AM
One other thing. My wastegate is internal and I was looking at the solenoid wire up diagram and since I dont have 2 p orts for the wastegate, then I'm not entirely sure how to wire up the solenoid lines.
Old Aug 12, 2008 | 05:11 PM
norconex's Avatar
Wires go the same way...its the vacuum/boost lines that change.
Port #2 should be connected to the intake manifold/boost source and #3 should be connected to the internal gate.
#1 is left open to atmosphere
...if I remember that correctly off the top of my head.
0% duty is min boost
100% duty is max boost
Old Sep 13, 2008 | 06:04 AM
SDHonda153's Avatar
Default Re: hondata boost control solenoid (norconex)
Question... I just hooked up the Hondata boost solenoid in my car yesterday. Running a Tial external wastegate I've got the top side hooked to COM and the boost/vacuum source hooked to NC of the solenoid, leaving the normally open to vent. (Wanted it hooked this way just in case of a failure I'd still be running off the WG spring) And the bottom side hooked to the boost/vacuum source like normal. Yet now when I start the car, there is a decently strong vacuum coming from my NO side of the valve. Is this commonly what happens and that's why they put the muffler there usually? Or I was thinking maybe I'm leaking air through my diaphragm in the WG. Wanted to get a second opinion before I went tearing into the wastegate. Thanks
three pac
Oct 22, 2010 01:53 PM
GReddy_Civic
Oct 18, 2009 10:21 AM
Pfieff
Dec 8, 2003 09:37 AM
Pfieff
Dec 2, 2003 11:45 AM
