axle swap do i need new fluid?
really if u hadnt change it in awhile just change it out. 2.5 qts of oem mtf or some syncromesh. cause i have an itr tranny i change it every other oil change. just because im paranoid haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">i just found out that GM syncromesh is discontinued
well i hope penzoil still makes them. parts number are the same just without the friction mod
</TD></TR></TABLE>well i hope penzoil still makes them. parts number are the same just without the friction mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HomeDepotMade »</TD></TR><TR><TD CLASS="quote">
well i hope penzoil still makes them. parts number are the same just without the friction mod</TD></TR></TABLE>
Friction Modified is where it's at, though.
Luckily I bought the last 6 quarts the local Chevy dealer had in stock. I went 50K miles on my last fill of SM FM, and it still looked good when I drained it out, so these 6 quarts should last me another 75K-100K miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c »</TD></TR><TR><TD CLASS="quote">it shouldnt leak that much....last time i replaced an axle no fluid came out and my trans level was fine </TD></TR></TABLE>
Your fluid level was way low then. Unless you jacked up the front right side of the car only. We did that on a friend's Civic one time and were able to keep the fluid from coming out while changing the axle.
Digithalgravel
Jun 10, 2008 03:24 PM
redpeppers
May 16, 2006 11:17 PM
