Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Power window issues
Old Aug 8, 2008 | 01:42 PM
krosrunner's Avatar
Default Power window issues
Hey i got a, hopefully, small problem. I have a 03 accord ex v6 2dr coupe and a few days back the passenger window wouldn't go down but then a few minutes later it worked, now the window doesn't go down at all, any ideas?
Old Aug 11, 2008 | 05:10 PM
spoonfedcrx's Avatar
Default Re: Power window issues (krosrunner)
Check the master window switch. I've seen my fair share break. If you take it out and look on the underside you may if yours is broken actually see it physically. Usually see it on the driver's button cause of all the use. It only takes a few minutes to check.
If thats not the problem. Pull the door panel and check to see if your getting battery voltage to the motor and check for a good ground. ?Make sure you leave both switches plugged in when checking obviously. Post back when you check.
Old Aug 11, 2008 | 06:13 PM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krosrunner &raquo;</TD></TR><TR><TD CLASS="quote">Hey i got a, hopefully, small problem. I have a 03 accord ex v6 2dr coupe and a few days back the passenger window wouldn't go down but then a few minutes later it worked, now the window doesn't go down at all, any ideas?</TD></TR></TABLE>
You may have hit the master child safe switch
Old Aug 12, 2008 | 08:53 AM
dramsey@vtaig.com's Avatar
Default Re: Power window issues (MSchu)
could be an intermitent short in the system, maybe when it gets hit? are you a still haveing the promblem?
Old Aug 12, 2008 | 10:56 PM
vtec.ftw's Avatar
yep its some sort of short ...
brandon123789
Jul 23, 2019 08:03 PM
WHiTETYPEs
Feb 9, 2005 08:57 PM
tomkocz
Aug 30, 2004 09:23 PM
southphillyman
May 23, 2004 04:56 PM
