Greddy e-01 HELP! wiring!
Old Aug 8, 2008 | 01:14 PM
riddlinkid1986's Avatar
Default Greddy e-01 HELP! wiring!
First off, like to say this is a good item an as a boost controller it works geat.
Im posting this cause THERE IS NO E-01 help any where, even through greddy its almost impossible to get what i need as far a info.
I have been DIGGING for over 4 months now, an still have so many questions that seems like no one can answer. I know there are a good number of people on HT that use this boost controller. So please feel free to share your info
Questions-
Dose anyone have the instruction manual for the Optional harness for MPH,THROTLE, WIDEBAND A/F?
Can i just hook up the Wideband Sensor to the e-01? Cause i hear of people doing so. True? False?
Has anyone ever hooked the Throtle & MPH on the e-01? can you take a pic of the harness an tell me where wires go?
Im really good with electrical! An reading digrams, but im going nuts trying to find this info!
From what i under stand, On the Optional Harness, That plugs into the MAIN unit for the Greddy e-01, There is a "ANALOG SIGNAL INPUT 1 (a/f 0-5v signal)" an a A/F Ground.
So, Im guessing that those would be hooked up to the map sensor? Just as you would hook up a VAFC to the map sensor.
ANALOG SIGNAL INPUT-WHITE (a/f 0-5v signal) =MAP SIG. in?
ANALOG SIGNAL INPUT-Grey (TPS) throtle
ANALOG SIGNAL INPUT-Green (Subaru v. clap boost cut)????-ANYONE EXPLANE?
ANALOG SIGNAL INPUT-Black (A/F GROUND)=MAP SIG out?
ANALOG SIGNAL INPUT-Blue (I/J DUTY CYCLE) ?????-ANY EXPLANE?
ANALOG SIGNAL INPUT-Light Blue (Crank/Cam angle signl.
Im trying to digure these out, can someone trace theres an give me some input!
Any info would be great! thanks for reading!
Old Aug 11, 2008 | 10:48 AM
Default Re: Greddy e-01 HELP! wiring! (riddlinkid1986)
bump! i know tuners read these posts!
Old May 5, 2009 | 10:37 AM
lude1888's Avatar
Does anyone know for sure what the wires are for the e-01 ext harness
1. light blue wire
2. dark blue wire
3. black wire
4. green wire
5. grey wire
6. white wire
riddlinkid1986
Aug 8, 2008 11:36 AM
civicboy1128
Jul 12, 2008 10:29 PM
civicudesire
Jul 11, 2003 06:08 AM
