HELP!!!! hatch wont start
im trying to figure out whats wrong with my ef hatch im running a d16 si swap i was driving and it just cut off its trying to start but if i gas it it cuts off if anyone can help me let me know
thanks. MILHOUSE_EF9
Code 7 is the TPS! make sure it is connected and if it is then get a meter and make sure the sensor is working properly. Use the search feature to find out what the readings should be.
im not sure which wire is which, but 1 will have 5v, anther is ground and the other is the signal wire which should be around .5v at closed thottle. with your meter on ground and signal slowly open the throttle all the way. the voltage should smoothly increase untill u hit WOT, the voltage should then be 5v or just under.
Junior1988
Sep 5, 2018 08:52 AM
thexbrothers
Oct 12, 2013 11:49 AM
