JDM ITR FRONT END CONVERSION LEGAL OR NOT???????
JUST BOUGHT A TEG FROM AUCTION NEEDS CHP INSPECTION, FRONT END STRIPED THINKING B
OUT PUTTING ON A JDM FRONT ,WILL I PASS WITH JDM FRONT CONVERSION ?
So anyone got ticketed for jdm front???
has anyone pass CHP inspection with jdm front?
all of these questions are regarding Ca...
Modified by hondamotor at 12:07 PM 8/8/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd94teg »</TD></TR><TR><TD CLASS="quote">yes sir</TD></TR></TABLE>
FAIL
NO it is NOT LEGAL (technically speaking). None of the components (hood, bumper support, headlights, etc) are US DOT certified meaning that its NOT legal. For example, there is no reflective material anywhere on front end. It is REQUIRED that the car have AMBER reflectors in the FRONT and RED reflectors in the REAR. This will get you an automatic FAIL in some states. Some states might not pass it just based on the fact that the headlights do not have a DOT stamping on them. Some states wont care about any of it and pass you.
So to answer the question... it is technically NOT legal and you run the risk of NOT passing depending on what state you are in.
/thread
FAIL
/thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOHN WAYNE »</TD></TR><TR><TD CLASS="quote">
FAIL
/thread</TD></TR></TABLE>
x2
FAIL
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeRightBack »</TD></TR><TR><TD CLASS="quote">it all depends on how much you invest into making it look right. if you spend the money to get it done right you should pass</TD></TR></TABLE>
Unless you live in Cali I can't see anyone failing an inspection for a JDM ITR front, but technically its illegal no matter what (not DOT approved).
OP you might not pass since you live out there. Not sure if I'd take the risk...
This is one question I've always wondered about. I'd be mo-pissed if I spent all that $$ just to have it denide on an inspection. But at least that something we don't have to be concerened with here in Alabama.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Not with a toothpick for a bumper support
Isn't there a thread in the archives somewhere about modifying the bumper a bit to fit the usdm bumper support?
Yes right here from markpaco
https://honda-tech.com/zerothread?id=488266 although pix links are dead
well im in CA and there are many JDM front integras, JDM front ITR, and RHD JDM front integras (including type R) running around so i would say. it is legal. BUT technically speaking John Wayne could be right (not saying he is or isnt). cuz i dont have a JDM front on my R so...
CHP inspection for title is for VIN inspection. They are making sure you don't have stolen parts on the car. If the engine in the car has a different vin or a different serial then you must provide receipts. For the front end they might ask you for a receipt to prove it is not stolen. They can tell the difference between OEM parts and aftermarket OEM replacement parts. Chances are they will not even notice that the front end is not USDM. Since your shell was a theft recovery the CHP will review the recovery report and will know what was missing when the car was recovered. They will see your front end and will know it is OEM and not aftermarket OEM. They will ask for a receipts from where you bought the parts from. If no receipt is produced they will take your parts off and will hold them and you can only recover them thru a judge/court appeal.
So buy your front end from somewhere reputable, do your conversion, cross your fingers and go to CHP.
It will pass the brake and light.
I was titling a 95 civic coupe once and it had jdm plastic headlights and oem clear corners. The inspection guy said you need the front blinkers to blink yellow/orange, I swapped the bulbs to orange bulbs and he was ok. He even aligned the beam of the jdm head lights. He did not say ish about the non dot lights.
will not pass chp inspection, the inspector looks at the headlights and sees no dot on it and fails it automatically
the headlights have to be approved by dot= department of transportation
well...... the hell with DOT.... so how if you use....for say "body kit" and its not even DOT as far as headlights.........what if you imported your car from japan, i seen cars been imported in cali and street legal.
FAIL
Living in a country where vehicle regulation and standard are really strict, I can totally agree to the statement above. A quick visual insection of cars that don't meet minimum safety requirement such as the ones stated above could lead to failure. It also really depends on who's testing a well.
In Japan, the inspection authorities that range from extremely strict to very relaxed. If you hit the extremely strict ones, unless your car is essecially all stock and in perfect condition, you will fail. Conversely, if you get inspected by a very relaxed authority, you could probably pass a track ready race car with only the very minimum street legal accesories (working headlights, tail lights, turn signals, and two front seats).
We're in the process of doing this now a a matter of fact, with our team car which is a 1992 Rover Mini Cooper. It has essecially no interior except for the minimum required by law (two fron seats, a steering wheel, seat belts, and a speedometer).
FAIL
if i want it, its goin on there Duhhh
