Need a sealant of some sort to seal off brake line leak.
Old Aug 7, 2008 | 11:16 PM
Hanmin's Avatar
Default Need a sealant of some sort to seal off brake line leak.
So I have the ABS gSR mc and 1 of the holes are bigger, I took the civic brake line, cut it, took the old screw out, and put a 12mm one in, flared it and i put it in, It leaks from it, I need some sealant, maybe honda bond? jb weld? or something that is safe around brake fluid that will seal it off. any input is appreciated.
Old Aug 7, 2008 | 11:55 PM
Hanmin's Avatar
bump, any input=] solder maybe? toothpaste? dried walnuts? anything.
Old Aug 8, 2008 | 11:41 AM
Hanmin's Avatar
bump bump bump bump bump bump
desperately want to put my motor in!
Old Aug 8, 2008 | 11:52 AM
Hanmin's Avatar
bump,, really desperate. anything, does anyone think jb weld will hold up to the pressure and not deteriate from the brake fluid? I just need a temp fix. something thatll hold for a yearish or something. I will find an rs booster and mc while im waiting.
Old Aug 8, 2008 | 12:02 PM
pepsiDX20's Avatar
DUDE, DO NOT USE ANY KIND OF CHEMICAL TO TRY TO REPAIR A BRAKE FLUID LEAK.
Brake pressure is too high and brake fluid eats through everything.
Take the line apart and re-flare it. Do it right, brakes are not something you want to be mickey mousing with.
Old Aug 8, 2008 | 12:04 PM
Hanmin's Avatar
the thing is, I dont think Itll flare out to that big. I'll give it another shot though.
Old Aug 8, 2008 | 12:33 PM
94EG8's Avatar
Seagull Management
Default Re: (Hanmin)
if the new fitting is larger then no its not gonna seal, no amount of flaring is going to fix this, and sealant, thats just unsafe, get the right size tubing, even if its only a foot of it, put another fitting on the other end, get a reducing coupler and then use the smaller fitting on the other line going into it. All this aside I assume your doing a rear disc swap on a civic? You could have just used a '91 EX MC and then everything would have just bolted up.
Old Aug 8, 2008 | 12:35 PM
Hanmin's Avatar
yeah, I got the abs gsr one for deals. and the 91 ex mc is kinda hard to come by. I'll be looking for an rs mc. Do you know where i can get the conversion things to make the 10mm screw go into the 12mm hole? I've checked a couple of stores and they didnt have anything thatll work, including schucks, home depot, and b&b.
Old Aug 8, 2008 | 01:02 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">yeah, I got the abs gsr one for deals. and the 91 ex mc is kinda hard to come by. I'll be looking for an rs mc. Do you know where i can get the conversion things to make the 10mm screw go into the 12mm hole? I've checked a couple of stores and they didnt have anything thatll work, including schucks, home depot, and b&b.</TD></TR></TABLE>
I think maybe you misunderstood, run a short length of brake line from the MC, then use a coupler that has a 10mm inlet on one side and a 12mm outlet on the other and run the brake line into the coupler, kinda like the coupler on the firewall for the clutch hardline. That actually might work for this if you can find one, it goes from a 10mm fitting to 12mm.
Old Aug 8, 2008 | 01:04 PM
Hanmin's Avatar
hmm, the hardest part of it all is finding one.
btw, do you happen to know the thread sizes? I'll have better luck finding it online.
Old Aug 8, 2008 | 01:09 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">hmm, the hardest part of it all is finding one.
btw, do you happen to know the thread sizes? I'll have better luck finding it online.</TD></TR></TABLE>
Not right off the top of my head, get a thread pitch gauge and check, i don't think they're all that much.
Old Aug 8, 2008 | 01:13 PM
itsmejto's Avatar
Default Re: Need a sealant of some sort to seal off brake line leak. (Hanmin)
You shouldn't be messing with mix-n-match brake parts if you want to stay alive, but if you insist you need a 12 to 10mm male/female reducing adapter from a brake parts specialist supplier. Then put the correct 10mm end back on the line.
IT'S YOUR LIFE ...........
fyi ... BRAKE LINES HAVE OVER 1000PSI IN EM, RUBBER HOSES/DUCT TAPE AND GLUE JUST AIN'T IN THE EQUATION.
oR . DO IT RIGHT .............
http://cgi.ebay.com/ebaymotors...ZWD1V
Modified by itsmejto at 5:19 PM 8/8/2008
Modified by itsmejto at 6:16 PM 8/8/2008
Old Aug 8, 2008 | 01:30 PM
Hanmin's Avatar
thanks alot! thisll fit a stock eg non abs brake booster, right?
Old Aug 8, 2008 | 02:22 PM
itsmejto's Avatar
yup, direct bolt up, don't forget to bench bleed it first or you'll never get it to pump fluid.
You can find used stuff, but I wouldn't go that route with brakes.
I see yah just bought it ????
Old Aug 8, 2008 | 05:55 PM
Hanmin's Avatar
yeah i did, kinda stupid though, my friendhad one sitting in his shop. aghhh. its a direct bolt on for the stock civic bb but not the integra one. kk, thanks.
dc4teg95
Mid-Atlantic (Sales)
Aug 21, 2013 08:45 AM
SirProject
Jan 29, 2013 05:32 PM
jonesEK
Jun 16, 2010 11:44 PM
MrParks
Jun 9, 2008 12:10 PM
ke98248
21
Mar 9, 2007 11:40 AM
