Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Autopower Roll cage question
Old Aug 7, 2008 | 10:38 PM
Abandoned Ship's Avatar
New medicines
Default Autopower Roll cage question
i have the 4 point bolt in street cage with harness bar. my question is why do i get a loud POP noise when i push it hard into some turns, usually weird angle turns. i know its bolted in tight i have checked the torque on all the bolts so know im just curious if this is normal?
if its n00b question i apologize in advance
Old Aug 8, 2008 | 03:48 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Autopower Roll cage question (Cryabandonship)
If all the bolts on the bar are tight, the pop is probably coming from somewhere else, like your suspension.
Old Aug 8, 2008 | 05:46 AM
jdm civic 2000's Avatar
Default Re: Autopower Roll cage question (Stinkycheezmonky)
i have had my 4pt for the last 5yrs,and i never came across what your mentioning myself.as stated by Stinkycheezmonky your issue could relate else where. i did get tired of re-torque each bolt and nut as they tend to come loose even when double nutted. so i welded it in. now im in the process of adding a u-weld front half to the exsiting hoop.
Old Aug 8, 2008 | 06:47 AM
JamesL's Avatar
Been using a the 4pt race bar for the past 4 years... no issues like the one you are describing.
Sounds like it is coming from the suspension.
Old Aug 8, 2008 | 07:00 AM
Suspetise...
To be more helpful, check EVERY bolt/nut in the suspension. Try identifying the general area where its coming from to make that easier. Put a wrench on it, don't just shake it or something. I found just such a problem with one of my rear upper control arms. If that still doesn't fix anything, look for something that might be rubbing/hitting, like your front UCA if you're running the car low.
Old Aug 8, 2008 | 08:14 AM
New medicines
ok thanks for the input, and no my car has a two finger gap and im running tein ht's.
its just weird cause it sounds like its coming from inside the car not underneath. i will double check all other suspension parts for proper torque
Old Aug 8, 2008 | 09:27 AM
Tyson's Avatar
Default Re: (Cryabandonship)
just curious, what makes you think its the roll bar? there are so many other moving parts that get loaded in a turn that could potential cause knocking issues.
Old Aug 8, 2008 | 09:41 AM
unrealwrc's Avatar
I get the issue of things sounding like there coming from inside as well. the problem is if you have removed seats/sound deadening mechnical noises can echo from inside the car. ( i don't have my sound deadining removed yet but everything else has been removed)
So this issue could very well be binding or loose components on the outside of the vehicle. Do you begin to hear a slight sound and then POP or is it just a quick POP?
Old Aug 8, 2008 | 09:57 AM
.:Made in OC:.'s Avatar
Default Re: (unrealwrc)
I have a autopower 6pt w/ no problems at all. Check your rear sway bar end links, maybe something loose?
Old Aug 8, 2008 | 10:15 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (.:Made in OC:.)
If it sounds like its comming from the rear check your trailing arm bushings, alot of them seem to wear out on the older honda's! Honda actually has a bulletin out for them
Old Aug 8, 2008 | 11:28 AM
dirty19's Avatar
Ridin Dirty in Cali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">To be more helpful, check EVERY bolt/nut in the suspension. Try identifying the general area where its coming from to make that easier. Put a wrench on it, don't just shake it or something. I found just such a problem with one of my rear upper control arms. If that still doesn't fix anything, look for something that might be rubbing/hitting, like your front UCA if you're running the car low.</TD></TR></TABLE>
Very good point Stinky!
Check the front upper shock surface just outside of where the shocks mount in the front.. If your bottoming out you will start to see dents from the front UCA.
Leave no part untouched by a wrench.. also look again at your springs with the load taken off.. they might not be seated.
Old Aug 8, 2008 | 10:24 PM
New medicines
no i have full rear interior and it definantly comes from the inside. the car DOES NOT bottom out pretty much ever. also it is only in turns not over dips or bumps. no rear swaybar. happened before the rear tie bar was installed, stock LCAs but has newer OEM replacement bushing.
thanks for the quick response!
Old Aug 9, 2008 | 03:14 AM
Suspetise...
Does it happen at the beginning of a turn, partway through, or the end?
Old Aug 9, 2008 | 06:36 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cryabandonship &raquo;</TD></TR><TR><TD CLASS="quote">no i have full rear interior and it definantly comes from the inside. the car DOES NOT bottom out pretty much ever. also it is only in turns not over dips or bumps. no rear swaybar. happened before the rear tie bar was installed, stock LCAs but has newer OEM replacement bushing.
thanks for the quick response!</TD></TR></TABLE>
I dont understand why you would have back seats with a roll bar
What kind of car is this on?
Whats a weird kind of turn to?
I still say to check the rear trailing arm bushings
Old Aug 9, 2008 | 04:39 PM
New medicines
Default Re: (B16B_coupe)
I still say to check the rear trailing arm bushings</TD></TR></TABLE>
no one rides in the back of my car. period. i keep for a clean look they have no function.
its an 1996 civic hatchback. its really only on off camber(?) turn and its usually half way through the turn. i will double check the bushing for play.
Old Aug 9, 2008 | 04:55 PM
SkankyEJ7's Avatar
You have to have an intact interior in many "stock" classes, This is why I still have my rear seat with a rollbar.
Old Aug 9, 2008 | 09:52 PM
B16B_coupe's Avatar
HRD PKR
its an 1996 civic hatchback. its really only on off camber(?) turn and its usually half way through the turn. i will double check the bushing for play.</TD></TR></TABLE>
Maybe try getting a sound clip? sounds like a bushing or something is loose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
You have to have an intact interior in many "stock" classes, This is why I still have my rear seat with a rollbar.</TD></TR></TABLE>
Whats that have to do with the thread?
Old Aug 9, 2008 | 10:25 PM
New medicines
Whats that have to do with the thread? </TD></TR></TABLE>
sorry i dont have anything that would work like that. i think ill have my friend ride as a passenger and hold the cage to see if it makes any movement.
the best i can describe it is as something building tension then snapping. its a very metallic pop noise. if i cant figure it out ill just unbolt the cage and see if it continues.
thanks again for the help
Old Aug 10, 2008 | 08:16 AM
Egezzy's Avatar
Spongebrad Squarepants
ima say it could be ur ball joint startin to take a dump.
Old Aug 10, 2008 | 08:23 AM
JamesL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Whats that have to do with the thread? </TD></TR></TABLE>
Well, he was explaining to you why someone might retain their rear interior while running a 4 pt roll bar.
Old Aug 10, 2008 | 10:46 AM
B16B_coupe's Avatar
HRD PKR
sorry i don't have anything that would work like that. i think ill have my friend ride as a passenger and hold the cage to see if it makes any movement.
thanks again for the help </TD></TR></TABLE>
I would almost loosen all the roll bar bolts and re tighten them, That way if it was caught in a bind or something it would re-adjust.
Do you have 2 nuts on each bolt holding it in? Let us know what you find out
Old Aug 10, 2008 | 02:00 PM
get RIGHT's Avatar
Do you have 2 nuts on each bolt holding it in? Let us know what you find out</TD></TR></TABLE>
That doesnt make any since though. I cant forsee a cage binding in anyway that it would POP in a corner and not UNPOP itself on the exit. I think he is gonna find that this indeed suspension/bushing related.
Old Aug 10, 2008 | 02:05 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (get RIGHT)
That doesnt make any since though. I cant forsee a cage binding in anyway that it would POP in a corner and not UNPOP itself on the exit. I think he is gonna find that this indeed suspension/bushing related.</TD></TR></TABLE>
This is true, but he seem's to think its the roll bar and not suspension related as i think it is. Since HE thinks its the roll bar i was giving him a ideaon what he could do for that
Old Aug 11, 2008 | 11:48 PM
New medicines
i couldnt ever pin point it but after messing with everything i dont get the pop any more
SpeedOFsmell
22
Apr 29, 2014 07:25 AM
brent_86
Apr 30, 2007 08:12 PM
lowgman
12
Jul 8, 2005 03:44 PM
DC4_MADMAN
Suspension & Brakes
Jul 6, 2005 09:11 AM
deviant1
Feb 29, 2004 09:16 AM
