oem JDM suspension VS oem USDM suspension
Old Aug 7, 2008 | 09:10 PM
mn_babyboy's Avatar
Default oem JDM suspension VS oem USDM suspension
Are they the same or is there anything different?
Old Aug 8, 2008 | 03:57 AM
JOHN WAYNE's Avatar
Default Re: oem JDM suspension VS oem USDM suspension (mn_babyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mn_babyboy &raquo;</TD></TR><TR><TD CLASS="quote">Are they the same or is there anything different?</TD></TR></TABLE>
i've always wondered this myself. i'm not sure if honda set up the front suspension differently to account for the driver being on the right side instead of the left. it should be pretty much the same though.
Old Aug 8, 2008 | 04:28 AM
tartje's Avatar
Default Re: oem JDM suspension VS oem USDM suspension (JOHN WAYNE)
98+ spec JDM suspension is unique to that market, they changed the spring rates and dampening a little which coincided with the increased diameter wheels
I don't know if LHD markets got slightly differently balanced stuff to RHD, I always wondered that too
Old Aug 8, 2008 | 04:48 AM
mn_babyboy's Avatar
Passwordjdm claim it's better than the US version. ?????
Old Aug 8, 2008 | 04:56 AM
tartje's Avatar
Default Re: (mn_babyboy)
they're probably talking about the 98 Spec suspension, ask for the part numbers and find out whether it is or not
Old Aug 8, 2008 | 05:15 AM
mn_babyboy's Avatar
I'll do that. Hopefully they dont b.s. just to get me to buy it.
Old Aug 8, 2008 | 06:08 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: oem JDM suspension VS oem USDM suspension (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">98+ spec JDM suspension is unique to that market, they changed the spring rates and dampening a little which coincided with the increased diameter wheels</TD></TR></TABLE>
Wow. I never knew that.
I always thought the rear sway bar was the only difference.
December 1999 - August 2008, and I never knew that, all this time.
Old Aug 8, 2008 | 06:43 AM
tartje's Avatar
Default Re: oem JDM suspension VS oem USDM suspension (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
December 1999 - August 2008, and I never knew that, all this time.</TD></TR></TABLE>
every day's a school day
Old Aug 8, 2008 | 06:58 AM
Todd00's Avatar
I said I don't want a title!
Really? We've had threads on this before. Way more back in the day, but even recently I think we discussed this.
Going by memory:
-the rear springrates on the 98 Spec R and USDM ITR are the same
-the front springrates are slightly heavier on the 98 Spec R due to wheels, heavier front end, etc
-front swaybar the same
-rear swaybar is 1mm thicker on 98 Spec R
-rear upper control arms on 98 Spec R are a bit shorter (slightly more camber) and are also not the stamped pieces that the USDM ITR gets. This was a popular upgrade back in the day for some odd reason
As far as shock valving...I have no idea. I'm not sure it was ever established if it was different from 98 Spec R to the USDM models or not. I believe shock part numbers were different, though.
Old Aug 8, 2008 | 07:17 AM
tartje's Avatar
Default Re: oem JDM suspension VS oem USDM suspension (Todd00)
yea, the dampers are valved differently too.
if I could be bothered to watch Type-R Legend I would post up the results, might do it this evening
Old Aug 8, 2008 | 08:07 AM
Doespike's Avatar
if I could be bothered to watch Type-R Legend I would post up the results, might do it this evening</TD></TR></TABLE>
Werd, the differences between 96 and 98 spec were in the vid.
Old Aug 8, 2008 | 07:22 PM
an2ny888's Avatar
Default Re: oem JDM suspension VS oem USDM suspension (Doespike)
also the jdm springs, both 96 and 98 spec, appear to be shorter than the usdm's, as well as having different colored paint marks
Old Aug 8, 2008 | 07:32 PM
SpoogenJay's Avatar
Default Re: oem JDM suspension VS oem USDM suspension (an2ny888)
that is a good question. hmm.... only thing i know that is different is the 32mm axles (US) and 36mm axles (JDM). other than that im under the impression that the suspensions are the same. dont remember the specs on the type Rx.
and also you have differences from the 96 spec and 98 spec JDM ITR.
Old Aug 8, 2008 | 07:36 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
Going by memory:
-front swaybar the same (25mm 98 spec vs 24mm USDM, 1mm larger)
Old Aug 9, 2008 | 04:41 AM
AltimaXX's Avatar
I was about to say...as I understand it the '98 spec JDM front swaybar is larger than the USDM.
Old Aug 9, 2008 | 07:42 AM
Todd00's Avatar
Default Re: (AltimaXX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AltimaXX &raquo;</TD></TR><TR><TD CLASS="quote">I was about to say...as I understand it the '98 spec JDM front swaybar is larger than the USDM.</TD></TR></TABLE>
Yeah, front sway is larger, 25mm JDM vs 24mm USDM. I forgot about that because hardly anyone upgrades their front swaybars on this chassis
I still find it amazing that Honda sent different ITRs to different parts of the world and hardly any of them were the same, even down to such detail as springrates.
Old Aug 9, 2008 | 08:48 AM
mn_babyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">also the jdm springs, both 96 and 98 spec, appear to be shorter than the usdm's, as well as having different colored paint marks</TD></TR></TABLE>
So If i was to buy a jdm oem suspension. Would you guys know the difference
CubbyChowder
Jul 10, 2011 08:16 PM
vti444
Jun 10, 2008 10:36 PM
1993gsrcivic
Suspension & Brakes
Nov 24, 2007 09:44 AM
oddmut
Jan 25, 2006 11:05 PM
