H22 mounts for eg
Everyone I ask says something different.............can somebody that actually has a h22 tell me.........i had mine in but it was cut and i replaced it because some1 told me with the hasport ones you dont have to cut anythin it jus bolts str8 up is that so or not?
I got Avid Racing mounts and I had to modify that tranny bracket. My friend has Hasport ones and it's a same thing. It might be the older version though, as his swap has been done couple years ago. I'm pretty sure because of the lack of space, modifying that bracket is required on all the kits. (I had to cut off 1"- 2" off and drill that small hole to get the screw through).
thats what i thought because i had to cut mine before but i changed that mount and was gonna go B series then some obviously dumb *** said theres mounts that bolt str8 up without cuttin anything
