Bouncing rpms help.
Old Aug 7, 2008 | 05:37 PM
leoaa777's Avatar
Default Bouncing rpms help.
Well, after searching for a while I decided to post a new topic since I could not find a conclusive answer.
I recently adjusted the timing on my d16y7 on boost. the people before me had done a hack job on it and it was @ 0* of timing. Super slow. Whatever, I fixed it and readjusted the dizzy correctly.
the car runs great now, builds boost faster etc.
The issue is that the rpms go crazy. the needle jumps everywhere, up and down blah blah. I can drive through the whole range and the car does not hesitate at all, even on boost. So the timing is correct. I tune on Crome with my laptop.
what can be causing this jumping needle? On the search someone mentioned the dizzy or ignition coil, the car runs great so I am discarding that ..or am I wrong. help.
Old Aug 7, 2008 | 06:21 PM
jdmthug's Avatar
check ur iacv...thats probobly it...u should be able to disable it on that crome pro ecu program
Old Aug 7, 2008 | 06:33 PM
leoaa777's Avatar
Default Re: (jdmthug)
Already checked, Its not an idle issue.
Its the rpms that go crazy. I have cleaned FITV and IACV just for the hell of it. Idle has improved but the rpms are nuts. lol
Old Aug 7, 2008 | 06:34 PM
blkegcoupe's Avatar
From: ....................................................................................................
its not the car or motor its the tune program crome causes some civics to that is it jumping for 1,000 to 3,000 back and forth? if so its the ecu tune its not bad and its not good but it doens't hurt your performance either
Old Aug 7, 2008 | 06:55 PM
DOUBLExDEUCEx22's Avatar
Default Re: (blkegcoupe)
what year and make? ive seen the same problem check your MAP sensor
Old Aug 8, 2008 | 12:25 PM
blk92_d16's Avatar
Ignitor, it's where the tach gets its signal from. Check the connectors on the ignitor to make sure they're on there good. I had the same issue and it turned out that only 2 connectors were loose and sliding around on the spade terminals. Used pliers to crimp them up and slid them on...worked like a charm!
Old Aug 9, 2008 | 05:49 PM
leoaa777's Avatar
Default Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 &raquo;</TD></TR><TR><TD CLASS="quote">Ignitor, it's where the tach gets its signal from. Check the connectors on the ignitor to make sure they're on there good. I had the same issue and it turned out that only 2 connectors were loose and sliding around on the spade terminals. Used pliers to crimp them up and slid them on...worked like a charm!</TD></TR></TABLE>
]Will do. thanks
Old Aug 10, 2008 | 05:09 PM
circuitEG6's Avatar
Default Re: (leoaa777)
ur timing is off, plain and simple
Old Aug 10, 2008 | 05:10 PM
circuitEG6's Avatar
Default Re: (circuitEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by circuitEG6 &raquo;</TD></TR><TR><TD CLASS="quote">ur timing is off, plain and simple</TD></TR></TABLE>
let me rephrase....ur ignition timing is off!
rexload
Engine Management and Tuning
Jun 7, 2009 06:50 AM
laziebun
Jan 26, 2009 03:43 AM
Boosted B18C5
Nov 21, 2002 05:10 PM
Boosted B18C5
Nov 21, 2002 02:27 PM
Boosted B18C5
Nov 17, 2002 09:51 PM
