How much oil to put in JDM ITR transmission.
Old Aug 7, 2008 | 01:58 PM
Boosted_01 R's Avatar
Default How much oil to put in JDM ITR transmission.
Looking at changing the oil in my ITR tranny, and not sure how much it is( 2.3 quarts?) Anyone knows please let me know. Thanks
Also what oil do you guys run?
Old Aug 7, 2008 | 02:02 PM
Doostur's Avatar
When I did mine it took just under 2 quarts to fill up. Just keep pouring till it starts to dribble out.
Old Aug 7, 2008 | 02:05 PM
Default Re: (Doostur)
Sweet, Thanks man
Old Aug 7, 2008 | 02:09 PM
Doostur's Avatar
O and use royal purple synchromax. Night and day difference !
Old Aug 7, 2008 | 02:22 PM
get RIGHT's Avatar
Mine took just over 2 qts.
Amsoil syncromesh.
Get it from Victor at http://www.vprmotorsports.com
Old Aug 7, 2008 | 02:23 PM
: ROYAL PURPLE SyncroMax
Great minds think alike, LOL that was the plan. Had used it on my last car: Integra LS shifting was as flawless/smooth as an S2K transmission.
Old Aug 7, 2008 | 02:27 PM
Doostur's Avatar
Its like butter, im a believer.
Old Aug 8, 2008 | 03:55 AM
JOHN WAYNE's Avatar
it should take 2 and then a little bit more...
it all depends on HOW you put the gear oil in.
if you fill it from the side filler hole with a tube and funnel, you will probalby only get about 2.25 in...but if you do like me and fill it with a long *** funnel after removing the VSS, you can get a LOT more in
i'm not sure if its good/bad, but one time i put about 3 quarts in that way and the trans felt smoother than it ever had. who knows?!
Old Aug 8, 2008 | 04:17 AM
JDM_320R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">O and use royal purple synchromax. Night and day difference !</TD></TR></TABLE>
keep hearing this, i might have to try it.
Old Aug 8, 2008 | 05:17 AM
IN VTEC's Avatar
Default Re: (JOHN WAYNE)
A lot of times I won't even bother checking it, I just put in about 2 1/4 to 2 1/2 quarts in.
At work, we have a 4 gal bucket with a hand pump and hook tube that we use to fill from the fill plug hole. You pump it until it dribbles out. Honda also makes a hand pump that threads onto the bottle top and you pump by squeezing the bulb.
Old Aug 8, 2008 | 12:48 PM
ITRBOY1433's Avatar
where do they sell the royal purple synchromax?
Old Aug 8, 2008 | 12:56 PM
The Dude's Avatar
Banned
Default Re: (ITRBOY1433)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRBOY1433 &raquo;</TD></TR><TR><TD CLASS="quote">where do they sell the royal purple synchromax?</TD></TR></TABLE>
I think NAPA.
Old Aug 9, 2008 | 08:40 PM
fastcrvi's Avatar
Default Re: How much oil to put in JDM ITR transmission. (Boosted_01 R)
get 3 quarts of MTF, drain and reinstall drain bolt, replace washers as needed. remove fill bolt and start filling until it starts to run out... just make sure your car is leveled..
Old Aug 10, 2008 | 08:14 PM
Devon M's Avatar
Default Re: How much oil to put in JDM ITR transmission. (fastcrvi)
I thought you were only supposed to use honda brand oil.
Old Aug 10, 2008 | 08:26 PM
Doostur's Avatar
Default Re: How much oil to put in JDM ITR transmission. (jdmeg6b18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6b18b &raquo;</TD></TR><TR><TD CLASS="quote">
I thought you were only supposed to use honda brand oil.</TD></TR></TABLE>
Old Aug 10, 2008 | 08:58 PM
Devon M's Avatar
Default Re: How much oil to put in JDM ITR transmission. (Doostur)
Otherwise, I was told it will eventually mess up your transmission. I cant remember why?
Old Aug 11, 2008 | 06:47 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6b18b &raquo;</TD></TR><TR><TD CLASS="quote">Otherwise, I was told it will eventually mess up your transmission. I cant remember why?</TD></TR></TABLE>
You must have read the owners manual.
Old Aug 11, 2008 | 07:42 AM
KetteringITR's Avatar
Default Re: How much oil to put in JDM ITR transmission. (get RIGHT)
[Quick threadjack question] I just recently replaced my tranny fluid with Acura MTF and got about 2 quarts in there and it was great but then this weekend, my car sat for a couple days and when i went to move it, it felt like i was shifting through mud. I know this isnt normal. Thoughts? Tranny flush necessary? [/Quick threadjack question]
Old Aug 11, 2008 | 09:25 AM
ITRBOY1433's Avatar
so what is it honda MTF&gt;&lt;RP Synchromax?
Old Aug 11, 2008 | 10:10 PM
clem kevin's Avatar
i used royal purple, save yourself and use something better like amsoil or motul
Old Aug 12, 2008 | 02:56 PM
DC4R27's Avatar
Default Re: (clem kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clem kevin &raquo;</TD></TR><TR><TD CLASS="quote">i used royal purple, save yourself and use something better like amsoil or motul</TD></TR></TABLE>
which motul fluid are you talking about?
blkboyan
Nov 18, 2006 05:14 PM
ECHb18cR
Jan 27, 2006 11:11 AM
turbotime
Sep 26, 2005 04:58 PM
UNVMYR
Nov 8, 2003 07:13 AM
douglas_be
May 18, 2003 11:07 AM
