97Civic Coupe Steering Column Issue...
Old Aug 7, 2008 | 09:31 AM
rcalzarette's Avatar
Default 97Civic Coupe Steering Column Issue...
Ok, I was missing the bracket that holds up the steering column, not the one that controls your tilt steering but that one that is like 6 inches lower on the column, It now has been replaced. My problem..... Still when I slow down it shakes the whole steering coulmn like crazy. I dont know what else to do. Everything is tight and I dont see anything that looks like it would be missing something. I have a beat axel on the driver side. Would this cause my dilemma or could it be anything else? Any help is appreciated. Thanx.
Old Aug 7, 2008 | 09:44 AM
hoo my gosh's Avatar
what the [freak] is a beat axle? do you mean bent? too much jdm horsepower!
Old Aug 7, 2008 | 09:48 AM
Default Re: (hoo my gosh)
no its not bent!!! there is no boot on the axle at all,the side that goes in the hub.now will that cause steering wheel shaking while brakeing,i did pads,rotors...tie rod end is good,upper control arm is good to,
Old Aug 7, 2008 | 09:55 AM
94EG8's Avatar
Seagull Management
Default Re: (rcalzarette)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcalzarette &raquo;</TD></TR><TR><TD CLASS="quote">no its not bent!!! there is no boot on the axle at all,the side that goes in the hub.now will that cause steering wheel shaking while brakeing,i did pads,rotors...tie rod end is good,upper control arm is good to,</TD></TR></TABLE>
Regardless of whether or not its bent, running axles without a boot they really don't last very long, at this point its probably run dry and its now most likely full of dirt, i don't know if its causing your issue, but due to not having a boot i'd replace it anyway before it leaves you stranded somewhere someday.
Old Aug 7, 2008 | 07:54 PM
Default Re: (94EG8)
bout a new axle today from etg auto parts,it will go in tomorrow morning.still havent figured out the shaking issue,also i think my hub on the driver side is bad it grinds when i drive the car new brakes and rotors ....
Old Aug 8, 2008 | 06:16 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcalzarette &raquo;</TD></TR><TR><TD CLASS="quote">also i think my hub on the driver side is bad it grinds when i drive the car new brakes and rotors ....</TD></TR></TABLE>
Thats more likely the outer CV joint failing from lack of lubrication, i've seen CV joints grind shortly before they completely flew apart.
noobaccord
Oct 25, 2011 11:54 AM
rachonda
Jul 5, 2007 06:54 PM
jdser92
Suspension & Brakes
Jan 6, 2006 04:25 AM
badpootie
May 4, 2005 07:23 AM
Nextelbuddy
10
Nov 25, 2003 06:14 AM
