can't get the turbine off any ideas
I have two turbos an one has quite a bit of shaft play side to side and back and forth and the other doesn't have as much. However I would like to swap the comprssor and turbine to the one with out the shaft play. However the one with play I can't get the turbine off at all any ideas on how i can free it to be removed..
ps one is a .42 compressor and .48 turbine (shaft play)
one is .386 turbin and nothing on compressor
i used some lubricant, and a hammer.... took a very very very very long time. eventually i got it off. turbo works like a charm right now.
R6E6I6D
Aug 23, 2005 10:50 PM
