Temp doesnt get hot
Old Aug 7, 2008 | 04:02 AM
b16a1eg6's Avatar
Default Temp doesnt get hot
In my Civic hatch with a B18C GSR swap, when I autocross it or on a track day the temp is fine but when I drive it down the road at 50mph the temp falls down almost to the first line on the gauge. Could it be my thermostat?
Old Aug 7, 2008 | 07:28 AM
CW-ITR's Avatar
Default Re: Temp doesnt get hot (b16a1eg6)
It sound like you don't have a thermostat in your engine. Another thing is your temp sensor may be bad.
Old Aug 7, 2008 | 09:36 AM
vtecb18c's Avatar
Default Re: Temp doesnt get hot (CW-ITR)
^ agreed....did you buy the car recently with the swap or did you do the swap? i had the same problem with a car i bought w/ a LS, they jammed somethin in the thermostat to make sure it would run cold i would think everything was fine...bunch of sneaky asses out there
Old Aug 7, 2008 | 09:54 AM
b16a1eg6's Avatar
Default Re: Temp doesnt get hot (vtecb18c)
Bought the engine from HMO. Did the swap myself. Guess I will have to pull the thermostat out and check it.
The temp gauge stayed right were it should through 4 20 min sessions at NHMS.
PphamEK
Feb 17, 2009 09:34 AM
LAO
Jun 3, 2008 06:24 PM
electric-boost
Dec 11, 2006 08:37 PM
blackpearlv6
May 7, 2006 08:26 AM
89 CRX SI
Apr 19, 2004 07:20 AM
