b16 wiring
i am going to be swaping a b16 into an eg the b16 is obd1 and i have all the mechanical stuff handled but i need some help with the wiring... i have basic wiring knowledge and i just need a list of what i have the do as far as wiring and if there is anything super intense maybe some instructions. thanks alot!
I swapped an OBD1 B16A into my 93 Civic EX using the D16 stock wiring harness. Everything connects perfectly except I had to get an o2 wire extension since mine didnt reach(I wouldnt recommend cutting and extending).
Also, my B16 didnt come with a map sensor so I took the map sensor off my D16 and hooked it up to a hose and stuck it on my B16.
Your gonna have to hard wire in your knock sensor or chip your ECU to ignore/remove knock.(I believe thats the correct way of saying it.)
Good luck
Good luck
