Fluctuating Tachometer as I increase speed
Old Aug 6, 2008 | 08:25 PM
Outrjs's Avatar
Default Fluctuating Tachometer as I increase speed
In all gears, the tachometer fluctuates rapidly and then climbs through RPMs normally. Just for a few instances needle fluctuates. No motor or decrease in power is noted. What could be the problem?
1999 honda prelude. Fixed clutch and flywheel recently. Rotor, cap, wires, and plugs new.
Old Aug 7, 2008 | 03:30 AM
oranginal's Avatar
Default Re: Fluctuating Tachometer as I increase speed (Outrjs)
there is a blue wire from the dizzy that sends the signal to the tach.
If the motor sounds normal it might just be this wire.
Open up the dizzy and look for where it connects to the ignitor, maybe it just came loose and you can just reattach it.
Old Aug 7, 2008 | 05:07 AM
prelude_93vtec's Avatar
And check your grounds. You can also try hooking up a tach to the blue tester wire under the hood to see if it's the tachometer fault or an electrical problem.
Old Aug 7, 2008 | 07:21 AM
pentaq's Avatar
Default Re: Fluctuating Tachometer as I increase speed (prelude_93vtec)
Could be a voltage regulator in your alt going out.
Old Aug 16, 2008 | 08:12 PM
Outrjs's Avatar
Thank you guys for your comments. When I changed the rotor and cap, I loosened the signal wire to my Tach. Pinched the wire and replaced it. Works perfect.
Old Aug 16, 2008 | 08:13 PM
Outrjs's Avatar
Default Re: Fluctuating Tachometer as I increase speed (oranginal)
Thanks for the information. I check the signal wire after I changed the cap and rotor. You were right. Loose wiring. Thanks.
Old Aug 17, 2008 | 08:00 AM
lude98SH's Avatar
Default Re: Fluctuating Tachometer as I increase speed (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">Could be a voltage regulator in your alt going out.</TD></TR></TABLE>
In that case you chould just check charging voltage and see if it flucuates alot.
Old Aug 17, 2008 | 01:51 PM
97ludedude's Avatar
Default Re: Fluctuating Tachometer as I increase speed (lude98SH)
It could be the tdc sensor inside the dist. The ignitor uses it to judge rpm. Then it sends the signal to the tach. If you can find a dizzy somewhere sway them out see if that fixes it.
Old Aug 17, 2008 | 04:43 PM
drbenne's Avatar
Default Re: Fluctuating Tachometer as I increase speed (97ludedude)
I think he fixed it already.
valentine97
Jan 18, 2008 09:36 AM
hspoon
Feb 23, 2007 06:30 PM
slimjimdanny
Jan 31, 2007 07:35 PM
97turboteg
Mar 21, 2006 08:00 PM
civicracer1993
Sep 17, 2002 10:53 PM
