99 SH Swap to 92-95 h22a
From: West Des Moines, Iowa, United States of America
Hey everyone i own a 99 prelude SH, and im currently in the mist of doing a 92-95 Swap. i have pulled the motor the and just got everything about ready togo but im stuck on the axles.
The breaks are disconnected and off as im waiting for the new ones to come. i have attempted a few different ways to get the rotor to stop spinning but everything fails, does anyone know of any tricks on how to stop the rotor from moving and to get the nut to break loose?
Also for anyone else that has done this kind of swap, could you put your two cents in about what was tough vs easy.. or anything or other parts i should buy that are needed to change the swap.. Thanks
R U talking about 99 to 92-95 as car swap or engine/tranny from 99 back to 92-95. I'm thinking, You are putting a 99 sh engine into a 92-95 fram. Please explain more.....
Im own the 99 SH and dont like the h22a4 engine. So i swapping the 92-95 h22a engine in to a 99 model.
I found that i need new axles
97-01 base mounts
Not sure of what else...
Any sites or following links would be helpful
97-01 base mounts
Well, to put h22a1 OBD1 into you 99 engine bay is doable. I haven't dont it that way but I would suggect to check with "Hmotorsonline.com. How ever, since your car is a SH, u need to have a OBD1 ECU , the current ECU won't work with out a slight modified (don't know how). Check with http://WWW.Rywire.COM, Peter is the guy to talk to about these OBD conversion. He might be able to help you out. Really helpful guy. Personal Experience.
c1civic
Nov 2, 2003 08:33 PM
