headgasket seeping oil
my headgasket is seeping oil form the rear timing side corner, is there any way i can fix this.
motor is h22a4, darton sleeves cometic hg, head and block have been resurfaced for being warped, arp head studs, motor has around 5000 miles all assembled by a shop.
Modified by dartonh22 at 6:03 AM 8/7/2008
make sure it aint the cam seals they leak and form a puddle on the h22 block deck towards the back seeming like a head gasket but realy a cam seal
yeah im starting to think its not my HG but i dont see any oil above the deck, its in a real b**ch of a spot and its hard to see if theres any signs anywhere else.
is your cam gear upper cover still being used? if not check under the seal to see if you have any signs of oil dripping down ...i just did 2 h22s with the same problem they put the hoonda bond on the seals with out thoroughly cleaning them ..usually once the oil is warmed up you will see it leaking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yus_fr »</TD></TR><TR><TD CLASS="quote">there is absolutely no OIL in the cam seal area !!</TD></TR></TABLE>
what do the CAM SEALS SEAL??
BigDare23
13
Oct 15, 2010 03:02 PM
.Ry
20
Feb 16, 2006 10:51 AM
-Whitey-
27
Nov 9, 2002 10:41 AM
