Suspension & Brakes Theory, alignment, spring rates....
really need help (stuck allen bolt)
Old Aug 6, 2008 | 03:20 PM
IAluder95's Avatar
Default really need help (stuck allen bolt)
so i bought a 94 civic ex. however the car is lowered in the front so far that the bumper is barely an inch off the ground. i want to reraise the car and when i went to do so, the allen bolt that allows you to adjust the height is stuck. i mean damn stuck.
any suggestions tips ect to pop that sucker out? i need to raise this car back up so i can turn the damn thing without rubbing the inside of the wells.
Old Aug 6, 2008 | 03:34 PM
Targa250R's Avatar
be professional
Default Re: really need help (IAluder95)
More torque may help; a better option than a standard Allen key is an equivalent sized 3/8"-drive Allen bit socket and ratchet:
However if it's seized, you may be SOL. More torque will only strip out or break the bolt, in which case you'll likely have to get another coilover sleeve & spring perch. You may want to call Ground Control and see if they can do anything for you as far as replacement goes.
If you do get it out, make sure to lube the threads of the bolt with anti-seize compound before reinstalling. This is good practice any time you have steel hardware threading into aluminum, and I always recommend it for the pinch bolt on Ground Control spring perches.
Old Aug 6, 2008 | 03:37 PM
VTECIntegra9's Avatar
take off the strut/coil and put it on the workbench and work on it there. may have to do some surgery to it or find someone who can remove it without damaging the strut behind it.
Old Aug 7, 2008 | 04:46 AM
Default Re: really need help (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Oh yes. Anti-seize is the nectar of the car gods.
Use it on every bolt that you might want to get out again
p.s. Any luck?
Old Aug 7, 2008 | 04:50 AM
IAluder95's Avatar
not a damn thing. i dont want to replace the suspension even tho it is shitty parts.
Old Aug 7, 2008 | 04:54 AM
i hate set screws.
did you try taking them off the car and working on it or those hex sockets?
Old Aug 7, 2008 | 11:13 AM
IAluder95's Avatar
hex sockets didnt work. and i havent taken off the suspension.
jdmvtecej2
Sep 18, 2008 10:03 PM
rhennin
Suspension & Brakes
12
Apr 12, 2007 12:16 PM
EM1VtecSi
Suspension & Brakes
Apr 25, 2005 02:18 PM
moleodonuts
19
Jan 10, 2005 02:07 PM
Buktheng
Nov 16, 2004 07:24 PM
