oem honda parts to upgrade a 95 civic cx
Old Jul 22, 2002 | 12:31 PM
civicmatt's Avatar
Default oem honda parts to upgrade a 95 civic cx
I'm looking for any oem honda parts that will bolt onto a 95 civic cx with minor modifications. I do not want to build a rocket, I just want cheap performance for my transportation while I am still in school. I already have a thermal cat back and a k&n filter. I am open to any parts interchanges. Also , is there a cam that will make noticeable power in a cx?
Old Jul 22, 2002 | 01:09 PM
shawnhayes's Avatar
Default Re: oem honda parts to upgrade a 95 civic cx (C5_ALLMOTOR)
get ahold of a 88-91 crx si head complete and bolt that on
Is this another version of the mini-me? Why wouldn't you use the head from a 95 EX???
Shawn
Old Jul 22, 2002 | 03:55 PM
Vanilla4215's Avatar
Default Re: oem honda parts to upgrade a 95 civic cx (shawnhayes)
Building up that cx motor sucks ***! There are only 8 valves in that thing! Try to change to head.
Old Jul 22, 2002 | 03:57 PM
B_CRUZ!'s Avatar
Default Re: oem honda parts to upgrade a 95 civic cx (civicmatt)
you have to change the head and the pistons. the pistons only have valve reliefs for 8 valves. 88-91 heads have 16 valves... it no workY.
Old Jul 22, 2002 | 06:23 PM
deez92's Avatar
Default Re: oem honda parts to upgrade a 95 civic cx (B_Cruz)
that b true
Old Jul 22, 2002 | 07:24 PM
civicmatt's Avatar
How do you know? Have you ever seen first hand the valve indents on the cx pistons? I'm not trying to challenge you, I just want a 100% answer, not a good guess.
Old Jul 22, 2002 | 08:11 PM
civicmatt's Avatar
If I bolt up a different head, can I still use my cx distributor? I would also like to stay away from vtec for right now. The wiring seems a little intimidating and not worth my time; I'm trying to squeeze power out of a cx!
Old Jul 22, 2002 | 08:27 PM
PisFacedSlappR_returns's Avatar
ohhhhhhhhhhhh **** you are setting yourself up for disappointment if you are trying to make power from a cx engine.70hp isn't the most potent powerplant in the world if you know what I mean.hahahahahahaahha
Old Jul 22, 2002 | 08:46 PM
saber1's Avatar
Default Re: oem honda parts to upgrade a 95 civic cx (PisFacedSlappR_returns)
What would the results be when mounting a EG EX head to an EG DX engine? Worth the time and money? Can it even be done?
[Modified by saber1, 5:47 AM 7/23/2002]
Old Jul 23, 2002 | 01:00 AM
Default Re: oem honda parts to upgrade a 95 civic cx (saber1)
Wouldn't that be the mini-me?
Old Jul 23, 2002 | 05:26 AM
mafioso102's Avatar
New User
DAMN IT PEOPLE
How many times do i have to post this! There are 4 valve reliefs per cylinder, even on the cx!! I have done a mini me swap on a cx! Do the swap.
People, if you dont know the answer, dont post it! Makes me question all the responses i get here on H-T
Old Jul 23, 2002 | 06:53 AM
Blurrrrr-SI's Avatar
Default Re: oem honda parts to upgrade a 95 civic cx (mafioso102)
Get it port and polished.
I am not sure what performance parts they make for the cx if anyone does.But I will search around a bit try and find somehting.
T-78RX7
26
Sep 4, 2012 04:10 PM
CivicHB95
Oct 15, 2006 06:44 PM
civicmatt
Jan 8, 2003 10:43 PM
