91 civic hub assembly help **searched**
Old Aug 6, 2008 | 10:01 AM
dirtyharryhatch's Avatar
A Digital Frontier
Default 91 civic hub assembly help **searched**
ok my wheel studs need to be replaced i am trying to take off the hub to take it to a shop so they can press out the studs and replace them with new ones ive been trying to find info on how to remove these 2 very annoying bolts that have like a joint in them one is connecting the steering to the hub and i dont know if theres a special tool or something,can some one help me out with some info?
Old Aug 6, 2008 | 02:27 PM
mcj_420's Avatar
Default Re: 91 civic hub assembly help **searched** (dirtyharryhatch)
Are you talkin about the the studs that hold the tire on? If so i just changed all of mine...all i did was take the brake caliper off then the rotor and turned the hub till there was a little space behind it and pounded it out with a 2lbs hammer. youll need a small chisel or screw driver to get them completely out and pound the new ones in. NOT SURE IF ITS THE RIGHT WAY BUT IT WORKED FOR ME.
Old Aug 6, 2008 | 02:45 PM
alscrx's Avatar
Are you trying to remove the whole spindle?
If so i think your talking about the outer tie rod thats connected to it....
Are you having trouble taking the nut off or seperating it from the spindle?
Also the second nut your refering to is probably the lower ball joint and nut.
Once the nuts are removed whack the control arm with a mini sledge or a regular hammer and you will see it pop out!
Old Aug 6, 2008 | 03:12 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyharryhatch &raquo;</TD></TR><TR><TD CLASS="quote">ive been trying to find info on how to remove these 2 very annoying bolts that have like a joint in them one is connecting the steering to the hub and i dont know if theres a special tool or something,can some one help me out with some info?</TD></TR></TABLE>
are you talking about the balljoints?? tie rod end and lower balljoint?
https://honda-tech.com/zerothread/1912773
theres also an upper one.
Old Aug 6, 2008 | 03:16 PM
A Digital Frontier
yes i was talking about the ball joint i bought the fork looking tool and it worked! iim happy but now ever shop i go to says that its better if i go to the junk yard to get the whole thing and not worry about changing the studs but thats retarded i needa buy a wheel bearing and a shop who can do it for me what a mission
ewoo
Feb 24, 2009 04:23 PM
simonEp3
Sep 3, 2008 04:49 PM
philkehn
Nov 1, 2006 09:54 AM
slowassR
Apr 30, 2003 01:44 PM
nikoniko
Aug 21, 2002 12:00 AM
