LCA bolt (bolt that is in the frame of the car) Welded nut with the metal bowl thingy around it
Old Aug 5, 2008 | 06:52 PM
aimbot's Avatar
Default LCA bolt (bolt that is in the frame of the car) Welded nut with the metal bowl thingy around it
Hey all, im redoing my suspension and a ton of bushings, and i have 1/2 of a b olt still in the frame of my car with the LCA bolts up to the frame. Ive drilled a LH drill bit and got pretty far, then tried a tap and it cracked in it. So my usual steps are just hacksaw the nut off of the end, then get a new one, but theres this metal bowl thingy covering the bolt. Is it possible to crack the welded nut off of the frame so i can just remove the bolt?
Old Aug 5, 2008 | 07:45 PM
M3Stylz's Avatar
Why not replace your LCA's they are so cheap
Old Aug 5, 2008 | 10:09 PM
aimbot's Avatar
Default Re: (M3Stylz)
Maybe i didnt explain very well, the bolt that connects the LCA through to the frame was not budging, so i cut the LCAs out. The remains of the bolt through the holes are what im having trouble removing.
Old Aug 6, 2008 | 08:01 AM
AlphaQup's Avatar
Default Re: (aimbot)
If you're talking about bolt #35, it should've came out without cutting anything. 99% of the time, the threads on the bolt gets caught after you've already unscrewed it, so you have to take a phillips screwdriver and stick it through the other side to push the bolt out.
Old Aug 6, 2008 | 01:41 PM
aimbot's Avatar
Default Re: (AlphaQup)
naw, impact wrench or breaker couldnt crack the bolt, its still threaded into that nut on the end of it.
Old Aug 6, 2008 | 02:16 PM
AlphaQup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aimbot &raquo;</TD></TR><TR><TD CLASS="quote">naw, impact wrench or breaker couldnt crack the bolt, its still threaded into that nut on the end of it.</TD></TR></TABLE>
Did you try spraying a lil wd-40 on there? What I did was use my T-bar and extended it onto my ratchet wrench to create more leverage. I know that bolt is on there pretty good, but it does come off.
Old Aug 6, 2008 | 02:27 PM
aimbot's Avatar
I applied heat to the big nut holding the rest of the bolt in and just snapped it off with a breaker bar. Thanks guys.
Modified by aimbot at 4:29 PM 8/6/2008
Old Aug 7, 2008 | 03:03 PM
Fuchueson's Avatar
Default Re: LCA bolt (bolt that is in the frame of the car) Welded nut with the metal bowl thingy around it
buy new LCA's, much easier, lighter, and looks better
I like my R
Aug 24, 2023 08:56 PM
spidermancivic
Aug 11, 2007 08:17 AM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
flip b18b
Jun 28, 2004 10:31 PM
logictron2000
15
Apr 24, 2003 08:59 AM
