diff between p08 and p28 ecus
i got a jdm d15b with a po8 cylinder head from a d16z6. i ws told both the d15b and d16z6 use the same cylinder head. which ecu is better to run with my d15b? i would think the p08 ecu but i have the p08 head from the z6. Im lost but what is the difference between the two ecus other then the fact there from different vehicles?
I would like to know this as well. I gots the jdm d15b, with p06 chipped/socketed and mapped to P28 (crome). When i asked the performance shop if i should try to find a p08, he said it wouldnt be worth it
prolly best thing to do would be chip it for tunning and get your own maps.
.prolly best thing to do would be chip it for tunning and get your own maps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by equ117 »</TD></TR><TR><TD CLASS="quote">i got a jdm d15b with a po8 cylinder head from a d16z6. i ws told both the d15b and d16z6 use the same cylinder head. which ecu is better to run with my d15b? i would think the p08 ecu but i have the p08 head from the z6. Im lost but what is the difference between the two ecus other then the fact there from different vehicles?</TD></TR></TABLE>
The P08 uses a 1 wire O2 sensor, does not use a purge solinoid and has slightly different fuel maps than the P28. The P28 uses a 4 wire O2 sensor and looks for the purge solinoid. They are very similar ECUs, the heads are the same btw, but the D15B vtec has a slightly more agressive cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirTyPreTTyThinGs »</TD></TR><TR><TD CLASS="quote">i wonder how diffrent the maps are?</TD></TR></TABLE>
For most people they aren't different enough to matter. I run virgin P28 in my sedan with a D15B vtec, it works great, doesn't seem to be running rich or anything. But if its a serious concern get a chipped P28 and use P08 maps.
